Help'''''. R34 Rb25 Gearbox Into R32 4Door Gtst Factory Manual
I have 2 year+ new oil that I've been collecting (left over oil from oil changes) fully synethic, I was gonna use as back up oil. Apparently the oil breaks down after a while, loses its properties but I haven't looked extensively into it. Otherwise would put the entire bottle in my engine.
By Watermouse · Posted
Sorry guys I won’t make it. Tried hard to have my car fixed but I can’t get her to rev under load. Can cycle through the gears in granny mode but have nothing over 3,000rpm if I need to hit the accelerator. -
By soviet_merlin · Posted
Hmpf, still dealing with the flu/covid/plague so won't make it this time -
Yeah, even here in SA they used to not allow coilovers if they could be adjusted (down) after they'd been inspected and "passed" at Regency, because....you could just drive away and lower it. But now they take the view that they may as well just pass them, and if you lower it below the limit then it's on you when you get defected and they will make your life harder on the subsequent clearance inspection.
