Hey guys
Got a rb25 with a copy greddy manifold
Just seeing where people run there water lines to that use to go to the back of the stock manifold ?
Can I make up a pipe to go in top rad hose and then weld a fitting on that for the water ? Pics would be great to cheers
http://www.skylinesaustralia.com/forums/topic/181826-how-to-greddy-style-plenum-install/
Pics don't work but should help.
What's your setup?
I ask because I haven't seen a mild setup benefit from this plenum. In that thread one guy made 4 kw more at the expense of losing midrange.
Personally I would look at the heap of cars making 300 plus rwkw with stock inlet and save the hassle of fitting the plenum.
Is that coolant return? Is it supposed to go in before thermostat or after? I cant remember
This is mine, but its a bit extravagant for your every day setup. The HKS kit I had before had a braided line that ran around the back with all the fittings to join to the rubber hose under the manifold:
It all depends what you are keeping and getting rif of as to how you do it ive kept the standard air bleed on my set up as ive tried to go the stock look, I ran a T piece at the rear and brought my turbo water feed around and over the top of the engine as it gave me better angles ect with the braided lines ive used but if your getting rid of the bleed from the stock manifold you only need to come out of the block and run it over to the turbo this makes life easier but be carefull to get all the air from the block.
Not sure how to post pics but if you need help pm me ya number and ill text pics or email directif you want more detail ect, Personaly having installed one of these manifolds (i got it new for $149) i dont think there worth the effort they are by no means bolt on if you want a nice neat job ive wasted hours redoing wiring and stuff that you just dont think of untill you start unbolting crap.
Cheers,
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
