Yep, plus the speeds are different.
Naturally these are sprint day speeds NOT happy laps speeds.
I normally enter the main straight at 100kmh and enter turn 1 at 140, the exit of turn 2/start of the back straight is also at 140-145kmh, the entry into turn 3 is about 80kmh and during a race you're breaking as late as possible. As you can see you have the potential to be going a lot faster at the end of the back straight than the front and the corner at the back is much tighter and slower.
I am keen to test that out one day Mike
I'm surprised you still have standard brakes on the SS
The speed you are carrying on the main and back straights + breaking late on that national circuit must ruin them
QR don't run sprints on the National circuit, only their general practice. When I was out last I got good laps but on my 4th I has some serious brake fade at the end of the back straight.
Brakes are mostly standard, BDA4000 slotted rotors and EBA Redstuffs and braided lines with RPF600 fluid.
so just need caliper upgrade
Steal Gregos Endless kit :P
Okay, so, I may have overreacted to my coolant system failure last weekend...
Genuine hoses and ebay radiator.
20588e87-bf66-4a12-a2dd-e28d0438731d_zps
probably the only part under the bonnet you can get too anyway,lol,that should fix it anyway.
Speaking of brakes - I know this is probably the wrong place to ask, but the right place for the people I'd respect the answer from most - what should I put on a V36 350GT? I have a very bad habit of warping or hotspotting discs in all my previous cars, and want to nip this in the budd before I start doing any damage.
was it you in that silver 350gt at last Happy Laps?
Not me, and I sure as hell hope it wasn't my car! Mine is Blade Silver...
I only just got it this week. So unless the dealer was giving it a thrashing I doubt it was mine! :P
Got any footage or pics, I could probably ID it if it was mine...
Edited by Simink
15 mins into mike's commentary lols
Next time less engine noise and louder commentary mouse! :P
What was so funny? My saying the Evo had fulleh hektic stretch?
Buy me an external mic then.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
