Computer art professionals!!! Please help...
Guys, could some nice person please change this animated gif of Domo shagging a rice cake, to Domo shagging an aero mirror?
An aero mirror like this: (the one on the right)
Is it possible? Just remove the rice cake and stick in the appropriately sized aero mirror?
I'm just totally crap at this kind of stuff! Thanks heaps in advance...
HAHAHAHAHAAAAAAAA!!! :bahaha:
...yooooou little punk!
Oi, I said the RIGHT aero mirror remember!!! Geez, is it too late to to change it to the right aero mirror (in the pic I posted of the aero mirror)?
You can't tell if it's an aero mirror or not in that animated gif... (not to mention you put a pic of my mug in there you little punk!)
:D:D
i did one test run with the right one in one of the frames... but you couldn't tell if it was an aero mirror or a strapon or just a black dot.
So I used the other one, and put ya mug in the reflection (notice the picture is reflected?) to indicate that you were watching domo go.
Just for those who don't know... it was actually Merli who suggested that I've got an aero mirror problem. Hence the gif...
Shan you little punk!
When I put the link for that animated gif in my sig using the [/img] tags, the gif doesn't come up, just a clickable link showning the link... am I doing something wrong?
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
