hesh12445 Posted June 23, 2014 Share Posted June 23, 2014 hey guys i have r33 gtr the rb26 head has been serviced with Hks cams Hks cam gears Valve stem seals and all replaced. R34 gtr ball bearing turbos still ceramic housing The car made 270kws at peak 21 but actuators brought the boost down to 16psi Now since yesterday the motor haa been blowing alot of blue smoke under boost load and on idle if you rev the car. The car was overfilled also bout 1.5ltrs of oil but i fixed that and now its perfect. How do i check if its my piston rings or my turbo seals blown ? Ever since it blew smoke it doesnt come on boost as hard Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/ Share on other sites More sharing options...
Blackkers Posted June 23, 2014 Share Posted June 23, 2014 compression test will give you a good idea Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7318970 Share on other sites More sharing options...
Ben C34 Posted June 23, 2014 Share Posted June 23, 2014 Yep compression test. Before that pull the intercooler pipe off the turbo and look for oil. Hopefully you will see some. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7318979 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 With the car having 264 cams and hks headgaste what would the numbers be for comp test? If its got oil in intercooler pipe does that mean turbo??? Thanks guys Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7318987 Share on other sites More sharing options...
Ben C34 Posted June 23, 2014 Share Posted June 23, 2014 (edited) Don't know what to expect. But what is important is that all cylinders are pretty much the same. It's extremely unlikely that all pistons would die at the same time. So the actual pressure result doesn't mean much, but the difference between cylinders is crucial. Oil going into to the turbo inlet is from blowby. Oil coming out of the turbo unto the intercooler pipes (with none in inlet) means it's the turbo leaking oil Edited June 23, 2014 by Ben C34 Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7318994 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Ok so if it was turbos that means it wouldnt blow into the exhaust if it blows into the intercooler? So most likely its motor? If its motor and i run a catch can will it fix the issue partially? The car doesnt go as hard now the blww smoke has come Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319000 Share on other sites More sharing options...
Ben C34 Posted June 23, 2014 Share Posted June 23, 2014 I don't know what you mean If oil is coming out of the turbos it will go into the intercooler pipework then into the engine and get burnt and make blue smoke. If there's tonnes of blowby all of a sudden a catch can might do something, but doesn't fix the cause of the issue. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319003 Share on other sites More sharing options...
KiwiRS4T Posted June 23, 2014 Share Posted June 23, 2014 Get some speed up without boosting in say 3rd or 4th and then (preferably on a long down hill (if you have such a thing where you are) take your foot of the throttle and after a few seconds floor it. A big puff of smoke will suggest oil being sucked past the rings. But compression test to confirm. If you have poor compressions no catch can will restore lost power - start saving for engine out! Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319004 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 The engine was sitting for 4-6months without use on a crate. The engine was never blowing smoke and all of a sudden it just started blowng smoke doesnt piston rings occur slow? Boosting ceramic turbos to 18psi I will check for compression if all good then would it be the turbos? Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319027 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Also my knock sensor shows high knock in 3rd 4 th since blue smoke arrived Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319030 Share on other sites More sharing options...
Ben C34 Posted June 23, 2014 Share Posted June 23, 2014 Busted ring lands happens very quickly. I doubt your engine just wore out. If comp test all good then it's likely turbos. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319051 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Im hoping its turbos i will do comp test and put up the results tonight see what you guys think Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319063 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Im hoping its turbos i will do comp test and put up the results tonight see what you guys think The oil was overfilled by atleast 3.5ltrs my negligence wouldnt that make it blow smoke? Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319236 Share on other sites More sharing options...
Ben C34 Posted June 23, 2014 Share Posted June 23, 2014 That's heaps overfilled. It could be the cause. Check the turbos inlet for oil. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319239 Share on other sites More sharing options...
Plattsy Posted June 23, 2014 Share Posted June 23, 2014 The oil was overfilled by atleast 3.5ltrs my negligence wouldnt that make it blow smoke? wut?! Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319246 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Yeh my dipstick popped out the other day while driving and im thinking because of overfilled oil and im guessing atleast 2ltrs came out and it was atill way pverfilled on the dipstick and it popped again and let oil out and still overfilled Im going to do oil change tonight and put lucas neil additive to thicken the oil and see if it stops the blowig smoke if it does then we know its rings and if it doesnt at least minimise th smoke then turbos Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319249 Share on other sites More sharing options...
Trex Posted June 23, 2014 Share Posted June 23, 2014 lel. I think he means 1.5 Still doesn't really make sense. Unless you're buying a drum of oil. Or almost tipping in a full 6L bottle. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319250 Share on other sites More sharing options...
Plattsy Posted June 23, 2014 Share Posted June 23, 2014 you drove it with plus 3.5? Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319251 Share on other sites More sharing options...
Trex Posted June 23, 2014 Share Posted June 23, 2014 Yeh my dipstick popped out the other day while driving and im thinking because of overfilled oil and im guessing atleast 2ltrs came out and it was atill way pverfilled on the dipstick and it popped again and let oil out and still overfilled Im going to do oil change tonight and put lucas neil additive to thicken the oil and see if it stops the blowig smoke if it does then we know its rings and if it doesnt at least minimise th smoke then turbos Just empty it to the correct height and see what happens. That lucas stuff is as thick as gear oil, it's for extreme circumstances. Not testing. Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319253 Share on other sites More sharing options...
hesh12445 Posted June 23, 2014 Author Share Posted June 23, 2014 Im guessing it was overfilled by atleast 2 ltrs but it was never blowing as much snoke the. Last couple of days so doesnt make sence. We will see soon what happens but atm still no idea Link to comment https://www.sau.com.au/forums/topic/444764-rb26-blowing-alot-of-blue-smoke-urgent-help/#findComment-7319384 Share on other sites More sharing options...
