Im guessing it was overfilled by atleast 2 ltrs but it was never blowing as much snoke the. Last couple of days so doesnt make sence.
We will see soon what happens but atm still no idea
You must have some idea.
It's either due to your crazy overfill.
Or engine has busted some ring lands
Or turbo seals have gone.
As discussed in this thread.
  • Like 2
Oil dipstick being forced out also sounds like excessive crank-case pressure build up.
Could be worn rings creating excess crankcase pressure or blocked breather setup not allowing crank to breathe.
Excess crankcase pressure could also cause oil seals to leak..
Ok my comp were 160s across the board.
I changed oil put oil thickner in it and it stopped blowing blue smoke under boost only sometimes and now it just blows on idle when revving blue smoke occurs and when coming of the excellerator underload it blows blue smoke
Its now blowing alot of black smoke and big flames and all of a sudden theres no performance in second gear!
Third gear is coming on boost but not as it use to very slow and not as crazy. My dipstick is blowing anymore and i checked my pcv hoses including one to the turbo and theres only a smir of oil but theres smoke coming out of the hoses have no idea what that means but no oil at all? Im leaning towards turbos only because the performance of the car is really bad and it all of a sudden running really f*kn rich?
Any thoughts i will not purchase a catch can if theres no excessive oil coming out the breather system. Maybe valve stem seals?
Any ideas im leanig towards turbos guys but again therre was only a smir of oil in the intercooler pipe nothing crazy
Yeah maybe you should stop driving it so much while there is a definite issue with the car, you could have even destroyed the turbos running that much boost. Park the car up and remove the intercooler piping to the turbos and have a look there like the guys have said. There shouldn't be very much oil but if there is pooling there that is your issue. Pull the dumps off at the rear of the turbos and have a look in there as well, you might be missing the exhaust wheel on one turbo. If you haven't got the mech know how to get that done just tow it to your mechanic and leave it there until it is diagnosed. It's not worth destroying your engine by running it and trying to boost while you have some major oil issue.
  • Like 1
Ok i am guessing it is valve stem seals as comp test shows all same readings across the board.
Turbors are very non responsive but still making boost just not as aggressive so thats 1 problem but im saying valve stem seals purely because it now happebs in 3gear and 4 th when i give it to about 6-7000rpm abd deexcelerate and let the rpms fall smoke gushess out everywhere like a bush fire abd its blue. Its there when im boosting it but jot as much as when im deexcelerating the car so my gues is valve stem seals i put oil thickner with 10/40 and did nothing at all?
Nothing no smoke when i remove cap or dipstick! When i remov the hoses for pcv system i see smoke coming out of the hoses?
Just a bit like very little smoke.
I will rip of all the piping tonight and look closer to the intrcopler for oil because i removed the big ass intercooler pipe near the Y pipe and smir of oil pn the pipe so thats why i discard it from being turbos though ill take of the pipe to the cooler and see if its all hanging down there i want an excuse to go single loll
The fact it doesnt do it on idle when cold shows me its only on revving down from high rpm and underload on boost and on idle when revving it!
I dont think turbos it might be but i dont think so there was a smir of oil in Y pipe i think valve stem seals or maybe a piston ring landin
The pinging was only here and there maybe happened 5times worse was 109 on knock sensor but after i changed spark plugs and drove it around stopped happening doesnt happen in any gear now?
Smoke accured after laat drive on sunday
Valve stem seals tend to show when you have let the car sit for a bit then take off. Does it blow smoke on startup after leaving the car for a few hours? If not I highly doubt it's valve stem seals.
Also I wouldnt be putting oil thickiner in an engine that takes thin fully synthetic oil
Cylinder comp test on cold i just did one on warm showed those results im not to worried about 1-5. They all show same its number 6 at 70. Now the question remains why it happened and what part went wrong and do i blame my tuner it lasted 2 days of dyno
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
