Hey folks, i bought a 350gt recently and was looking into getting a cruise control system for it, however the places ive tried locally (Townsville NQ) noone even wants to look at it. I should be capable of installing the system on my own, i was just after some advice or suggestions on where would be a good place to buy the system, and the buttons for the steering wheel. Thanks in advance
https://www.sau.com.au/forums/topic/444771-350gt-cruise-control/
I bought mine from Commsman a while back, he put together several for sale, don't think he has any more though, but he might be able to tell you where to get the parts from. Works very well and he sold it with the factory steering wheel controls, so it all looks like a factory setup.. was about $600.
But really, any cruise designed for a DBW throttle should work.
Otherwise Chris Rogers will be able to advise.. not sure if he sells the kit though, probably supply+install only.
Have been considering 'frankestining' my speedo cluster to add the 'cruise' and 'set' lights for mine.
I'm assuming the aftermarket cruise control lets you set the speed above 100km/h?
Unlike the factory one from Japan which only allows up to 100km/h
Also Can you post a pic?
yes, it is an aftermarket unit, so it isn't limited like the dealer option.
What do you want a pic of? the only thing visible in the car is the factory cruise control switches which look like these - http://www.ebay.com/itm/INFINITI-G35-SEDAN-STEERING-WHEEL-AUDIO-CRUISE-CONTROL-SWITCH-OEM-/151225242020
Unless you have a Momo or other steering wheel like mine...
I then used the stalk, which was an easier install, and also gave two preset speeds as an option.
It looked like this...
http://www.rutlandcommunications.co.uk/default.asp?ContentID=93
Better than the VDO buttons I have now on my V36..
http://tgcinternational.com.au/images/P/p-03.jpg
Sorry to hijack the thread. On the topic of cruise control. I'm going to get the top spec V36 370GT. I don't know whether to get it with cruise control or without?
In terms of converting it so you can set the speed limit above 100km/h. Anyone know if it's like the Sat Nav conversion in regards of money, cheaper to get it without cruise and just whack on a new one, or same price or dearer to convert the factory one it comes with?
Thinking Chris is probably the one with the answers but if anyone else has info on the matter, can you please let me know.
Cheers
On the V36, cruise control is optional even for the SP grade. It's difficult to retrofit as you need to have steering wheel controls which can only be ordered along with the steering wheel itself.
The full "cruise control" package according to the specs has the following:
  • Steering wheel switch (audio, navigation, hands-free phone, intelligent cruise control)
  • Intelligent cruise control
  • Front seat emergency brake sensitive pre-crash seat belt
  • Intelligent Brake Assist
It is unlikely that any random V36 will have this option fitted, so you may need to spend extra months on auctions if this option is a must
I wanted this origionally... But in the end it was limiting me too much in car selection...
Just bought the best car I could afford, and fitted cruise once it was landed in AUS. Yes I don't get the radar/laser range sensor in the front bumper and the lights on the dash telling me it is working, but it holds the car at constant speed, and works at any speed I want it to..
P.S. the cruise and audio controls are available on eBay from the US quite easily, asssuming that the G37 ones are compatable...But you will need a new steering wheel insert, as stocked by Chris, to install them.
Edited by nickcorr
Thanks for reply. I already know it's an extra option. What I really need to find out is if the factory cruise control it comes with can easily be converted to allow the speed be set above the 100km/h it is limited to in Japan. Much like how the car's speed is limited to 180km/h in Japan but if a speed limit Defencer is fitted in Australia, which is a cheap and easy fix, it will allow the car go to its max speed.
I really do t see why you are looking for something that cannot be modified. You are not talking about an 80s car here where a Zener diode and a few components worth the speed issue.
Speed on the 36 series is DATA driven.
Nick has it I a nutshell. I sell both the 35 series and 36 series as full kits. The 36 series I sell complete with the CORRECT controls (of which there are 6 variants) and the wheel control housing.
You lot make things entirely too difficult for yourselves.. Seriously.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
