So I bought this with about (81000 kms) for $9.5k.
I have broken up the build in terms of different stages spanning about 6 months since I brought the car
These are the specs:
Stage 1 (135 rwkW & 340 Nm Torque & 10 PSI)
· Engine: Internally Stock
· ECU: Mines Stage 2 ECU running at 0.9 Bar
· Drift Handbrake
· Momo Steering Wheel
· Defi Boost Gauge
· Full Roll Cage
· Wide body kit with GTR front bar and lip
· Wheel: Wolf Racing SP1 Wheels
· Coilovers
· Front and Rear Brace
· Interior Brace
· Blitz Pod Filter
Stage 1 (135 rwkW & 340 Nm Torque & 10 PSI) Driveability
The car was running very rich and massive camber on the fronts which made basically made it not driveable in the wet
Stage 2 (230 rwkW & 503 Nm Torque & 18 PSI )
· ECU: Link G4
· Injector Dynamics ID100
· Billet Performance Products (BPP) Fuel Rail
· Fuel Labs Fuel Pressure Regulator
· E85 Walbro Fuel Pump
· PWR Intercooler
· Pod Filter Relocated into wheel arch facing front bumper vent
Thought this would be enough to get 190 rwkW with the stock turbo, straight onto the dyno tune and the Clutch slipped when boost was increased to 13 PSI, and took the opportunity to upgrade the turbo
· Clutch: Competition Clutch Stage 2.
· Competition Clutch RB20 Lightened Flywheel.
· Hypergear ATRSS1 Turbo
· 3 Inch Dump pipe
· High Flow CAT
· CAI: Dropped the Blitz Pod Filter Down into the wheel guard but facing forward
Driveability:
Full boost hits at approximately 4500-5000 rpm and throws you into the back of the seat.
The clutch itself is very light under foot compared to my R34 with Exedy heavy duty clutch. My preference of the two is the competition clutch but the only question is as to whether the Competition Clutch will last as long the Exedy clutch.
Major problem was when I did a track day and the radiator depressurised coolant everywhere, equally concerning was the brakes would fade after about 15 mins (30 km) on track. Clutch fan had about 10 cracks, so it was about to shatter I suspect.
Stage 2 (280 rwkW & 700 Nm Torque & 22 PSI)
· EFlex Sensor to allow switching between different ethanol concentrations and 98RON.
· 62 Inch Carbon Fibre Drift Wing
· Rota P42r2 (Matt Black), 18x9.5 (Front) and 19x 12 (On the rears, thankyou wide body kit!), Achilles Tyres all round
· Front Camber Arms
· Twin Thermo Fans
· DBA Slotted and Cross Drilled Rotors with EBC Red stuff, Motul RBF600 Fluid
· Reconditioned Brake Master Cylinder
· Denso Pencil Coils
Stage 2 (280 rwkW) Driveability:
The Pad/Disc setup took almost 500 km to get rid of the squeal and the noise is still there initially when it’s cold.
Initial issue was the car wanting to spin when the brakes were applied, reconditioned the brake master cylinder and all was good, seems like the brakes were biased to the rear resulting in twitchiness under brakes.
With the E85 it feels like the power comes on much quicker but most really just more power at the same rpm. The car still gets wheel spin in 3rd and 4th when boost comes on
The gearbox still feels tight with the power, no noises or anything so hopefully it holds out for a while yet!
Overall generally the car is very much street able and comfortable to drive which was surprising.
Future Plans
Currently the plan is just to enjoy the car and work on setting up the suspension and rear wing to maximise track performance.
https://www.sau.com.au/forums/topic/444774-njs-r32-gtst-build/
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
