Theres a plug in the engine bay, just in front of the fuse/relay box. It joins the gearbox harness to the rest of the car. Mine was dirty and my reverse lights sometimes went funny then all of a sudden stopped
Simplistically, I would imagine the following:
Switch at the g/box
globe at the rear of car
fuse in the engine bay
and wiring to join it all together...
If you've multi'd the switch (when closed!), checked that the globes actually light up under a power source, then there is only the the wiring and the fuse to check.
That being said, did you check the switch for continuity? I found with my box/switch (R33 RB25), the only way I could verify that the switch was good was using a test light and a mini 12V battery.
Multimeter did not display/sound continuity unless powered!
Edited by R32Abuser
My reverse lights work for a second when I put it into reverse then go off. Not sure what it is they used to work when I pulled and held the gear leaver back but now they only work for the second when I first put it into reverse. Any one had this before? Thanks
Locate - Yes.
Troubleshoot - depends on how mechanically/electrically minded you are!
There is a plug at the reverse switch (on the gearbox) and in the engine bay where it joins back into the wiring loom.
Ground - I'd have to take a look and the wiring diagram to see exactly where the circuit is grounding. Something I neither have the time or the patience for at this time of the night.
Edited by R32Abuser
After checking everything again, still couldn't find the fault >.
What did you "check" and how?
He also checked everything and still doesn't work. ....
Something isn't being checked correctly.
Agreed.
As I said above, I had issues testing the circuit without having reverse selected and powered. Otherwise I got nothing...
Edited by R32Abuser
I've had the wiring diagram out
There is a plug at the tail-lights (obviously), a plug drivers side top front of boot (this may be out of sight inside the guard, I'm not real sure), the plug at the front which I mentioned before and then the plug at the switch on the gearbox
I cant find what fuse it is tee-ed off, but there are a fair few things powered off the same circuit like the de-fogger relay (rear window) so if thats working I dare say the power source is O.K.
Basically just need to test the switch, or bridge out the plug to eliminate the switch completely. Get the lights working without the switch and then you can see if the switch works. If you have power at the switch harness, then the earth is at the tail lights. If you have all the other lights + number plate lights then Earth is most likely not your problem, the Earth is common to all of them.
OP has already said he has tested the switch and it is O.K.
My switch could test fine to, i could also wiggle the gear stick while in reverse and get reverse lights going for a few seconds. Was very weird new switch fixed it. No idea if that's OP problem. Just a thought
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
