I was wondering if I did the electrical part of this mod right. I took all the lines and solenoids out, one under the rear suspension area and the next up front by the intake manifold.
Next I took all the hard lines off the bottom of the vehicle. I then looped the cooler line back in from the supply line for the solenoid that was around the intake manifold.
The part I'm worried about is the modification of a wire that i should cut on the hicas ecu. The instructions I followed is for the gtr and was wondering if its the same for my r32 gts4? ?? I cut the green with white strip wire please check the attached photos for more detail.
Thanks
https://www.sau.com.au/forums/topic/444801-r32-gtr-hicas-delete/
that would be to stop dash light, I just de-pinned, hicas ecu still in place
Yes I had two options. One was to remove the actual bulb but was not the best option. Next was to cut this wire to stop communication from hicas computer. It seemed to be the best solution. But I just wanted to know if it was the same as a r32 gtr.
I will post the link used for the modification.
Edited by MJTru
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
