Recently bought a '92 R32 GTS-T Last night it started leaking Coolant from the bottom radiator hose where it connects to the block, So i got a new pipe. went to fill the radiator with new coolant and I noticed the old coolant was filled with rust and also a white foam was also coming from the top of the radiator. I've had a quick look around the internet and the internet tells me I my Headgasket is gone. BUT I have never had an overheating issue, the car actually takes a while to warm up and sits at 70-80 degrees C all the time. What should I suspect needs fixing??
https://www.sau.com.au/forums/topic/444823-white-foam-in-radiator/
Flush the system and fill with distilled water for a few days, run the car as normal and if you've had no problems previously it shouldnt be an issue, just keep an eye on the temp. Just to make sure you have an issue before you start doing major repairs
That's what I'd do anyway. Unless you know that the radiator had good coolant in it and had been well flush before the coolant was put in
I've also just noticed it's actually eaten quite a bit of oil lately as well... but again never had an issue with heating which keeps me hoping its not a head gasket.
Or, hopefully its just the head gasket and not f**ked piston rings too....
Edited by angusis2fast4u
Yeah well you might have a problem there then. What does the oil look like? Is it milky at all?
Depending on where everything is being lost will make a difference to the symptoms. I just changed an inlet manifold gasket on a VS commodore ute (V6) because I've been losing coolant in it for ages and when I did the last service noticed milky oil around the filler cap. Pulled the manifold gaskets out and saw there was a problem with the seal around one of the water ports that was close to an oil port. Obviously a little coolant was bypassing into the oil
Coolant still looked perfectly fine, oil not so much. I originally thought it might have been head gasket but so far looks like it was the manifold gasket. Havent driven enough to know for sure yet but I hope its fixed, bit of a crap job really. Looked easier then it was anyway
Edited by 89CAL
Oil looked fine. I have been explained that on these engines oil pressure is higher than coolant pressure so finding oil in the rad while not having contaminated oil is more than likely to happen. Might as well chuck in a 25det...
I think all engines have higher oil pressure then coolant pressure. Seen as coolant pressure is usually only maximum of 1bar
The example I gave was coolant entering oil return ports so no oil pressure
It is a bit irrelevant to a 25 seen as there are no oil returns in the intake manifold but there are more oil returns then feeds so it is still a possibility
If it's losing coolant and oil it could well be head gasket but could also be other causes if the coolant and oil are leaking in different spots
Very hard to diagnose over the Internet so just floating ideas around
Yeah I know thanks for the help though man, it's good to get advice on testing out possibilities. I will stay 20, just because I prefer this engine over 25. Gasket seems like it should hold up for a few more weeks yet So i might go buy a reco 20det and just clean it up and dump it in when i can, I have to do the box aswell so might buy a 20det in a combo with box. All i can say is that choclate milk/rust and white foam doesn't show up in the rad unless the head is gone so all i can do is replace it and hope...
Rust and white foam?
I wonder if someone threw a can of bars leaks inside?
Exactly what I thought.
I mentioned I his other thread about the kits to check for head gasket leaks in the coolant.
I would definitely do that first in this case.
thought this also - sounds like it
take the cap off and look rub your finger in there
bottom radiator hose off and flush.
Look for dark little granules like mouse/rat pooh
when I emptied the coolant into a bucket there was a layer of like rust dust on the bottom of the bucket. other than that Oil is clean, but oil has been eaten and it's not giving blue smoke. no bigger chunks of matter though like rat poo size. There seems to be water/coolant always in the exhaust on start up - it happens always, can't always be condensation. (if you put your hand at the exhaust tip water will come out for about 1-3 mins till i guess it reaches a temperature where it comes out as a very fine smoke (smoke is not that visible and blends in with normal exhaust fumes). Coolant did come out brown/Choclate milk...
Flushed it a couple of times, put water through, put flush and water through and then filled with coolant. Never put my finger in the bottom hose but never saw any "rat poo"
Can't think of anything to explain it further. I got an opinion off a mate who came and had a look at it and he has been working on engines espcially rb20's and rb30's for a while now, and he is pretty certain its the head gasket. just don't want to put all my trust and MONEY on one opinion. I guess it could be many things but i won't know till the head comes off.
Plan so far is to replace the head and take it to a professional to have it flushed properly to get out all the shit coolant side and oil side. just to be safe. head should come off this weekend so I will know then the extent of the damage :/
Take it to a place like Natrad.
They will tell you for certain if it is in the cooling system and if your head is blown. They measure CO2 in the fluid.
As GTRPSI pointed out if the "ratpoo" has dissolved you wont find it. It is designed to dissolve with temprature and block small/minute holes in the radiator (small leaks) under the pressure.
Ps. It never works but will turn your water milky and through movement and air frothy.
However if barsleak was put in recently you would find it very easily
Edited by Sinista32
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
