Hey all,
A few of us went to Oktoberfest last year and it was a good day so thought I would put it out there that we do it again!
http://www.oktoberfestbrisbane.com.au/about/essentials/
Location: Brisbane Showgrounds, Bowen Hills. Entry only via Gregory Terrace.
Date: Saturday, 18th of October
Time: 11am onwards, we will be there at 12noon.
Cost: Tickets online $21.00 or at the gate $24.00 plus there is food and drink obviously :cheers:
Dressing in Oktoberfest getup is optional but awesome if you do, I will!
See you all there!
Attending:
Melly
ZCR
Smity42
Cadmoon +4
Kiwi_Phil +2
Sick_R31
t5iv
  • 3 months later...
Tickets are purchased at the group rate for:
Melly
ZCR
Smity42
Cadmoon +4
Kiwi_Phil +2
Sick_R31
t5iv
If anyone else is keen you can still get individual tickets online or at the gate :)
I'm keen, but I'll be in Sydney at WTAC getting high on E85 fumes
Unfortunate timing... Both events with much fun to be had!
Also if you see James (Grumblebee) tell him Mel and Zane said Hiiiii! And Nick... Also tell Nick... :)
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
