Hey, I have been slowly building up an R33 Gtst track car over the past 5 or so years. I feel that the car is just about where it needs to be in terms of upgraded/strengthened/adjustable parts now but i am having trouble dropping my lap times mostly due to oversteer.
I am hoping there is some knowledge out there that you might be able to share with me.
Here is a video of how the car goes at the moment which also should give you an idea of its handling characteristics.
https://www.youtube.com/watch?v=PeUwsz22pOU
and here is a basic rundown on the car and setup.
It is a 96 S2 Gtst with a steel wheel holset core and about 240kw
Interior
- Stripped interior about 180kgs removed
- 8 point roll cage
Handling
- Bilstein shocks valved for track work
- Springs 350 front 550 rear
- Ikeya formula front upper (front set to 3.2 negative)
- Ikeya formula rear upper (rear set to 1.6 negative)
- Ikeya formula rear toe (pretty sure toe was set to neutral)
- Alloy subframe bushes
- Polly bushes just about everywhere else
- Nismo 2way LSD
- Hicas Lock bar
- Height adjustment set to about stock
- 20mm spacers
- Federal FZ201 semi slicks (about 34psi hot in front and 32psi in rear)
There are other RWD cars running similar setups and power to weight lapping 3-4 seconds faster, now obviously the driver is going to have a big impact here, but looking at there videos they seem to have a lot more corner grip and stability.
https://www.sau.com.au/forums/topic/444856-r33-gtst-handling-advice/
either im blind or you dont mention sway bars.
these are a must.,
if you do have them, soften the front sway a little, it will correct the oversteer.
just my little 2c on the limited knowledge i have.
The initial understeer is what worries me,,,gts-t's don't usually suffer from that. It's certainly not the tyres,,, FZ's are great but your tyre pressures are way different than me,,,I use on a hot day 38 all round and constantly adjust them till I get it. Zebra's on drugs,,,no way is your diff contributing,,,no way. I'm running close to 0 camber on the rears and about 4.5 on the fronts from memory. Artz is right she needs to be lowered,,,big time.
Just do little changes,,,or you will never know what fixed it.
Cheers
Neil.
Yeah hard to recommend changing swaybars when the car is exhibiting both under and over steer.
I found this interesting camber vs tyre pressure info that I will have a go at next track day http://www.turnfast.com/tech_handling/handling_pressure3
I will also lower it a couple of centimetres just a pain for road driving.
I am going to peg rear camber back to about 1 degree if this fixes the rear end grip then maybe i can adjust sway bars to reduce understeer (softer in the front or harder in the back although the links on the whiteline kit seem to only fit in some positions)
You stated the tyre size, but size wheels are you running front and rear? If you're running narrower front wheels and tyres, try running the same front and rear. I think you'll find it makes the handling
a lot more neutral. Also, a bit of toe out on the front will help with turn in and that corner entry understeer. Goodluck, and keep us posted.
You are correct on rim size im running 8" on the front and 9" on the rear.
Interesting I need to get some lighter rims current are about 9ks a piece, will take this into account when i upgrade.
What do you reckon 9" front and rear running 255s?
this counters understeer not oversteer.
Nope, softening a front sway bar will correct understeer..so I just figured stiffening it will help with oversteer...
ED*
though if you look at the graphs below ther eis no clearcut solution really as softening and stiffening can fix it, depending on situation
I have been reading up on this all week man cause the cressy is understeering mid corner, been looking for a solution :P
That's what I would be doing. And then, if it still has mid corner understeer, soften the front sway bar one notch.
thats what i read it as.....why are we all talking understeer now?
Also i dont think rim size is going to make alot of difference, mine felt perfectly stable with 8s and 9s..dont get me worng it will help, but i dont think it is something to really be concerned with.....
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
