Hey, I have been slowly building up an R33 Gtst track car over the past 5 or so years. I feel that the car is just about where it needs to be in terms of upgraded/strengthened/adjustable parts now but i am having trouble dropping my lap times mostly due to oversteer.
I am hoping there is some knowledge out there that you might be able to share with me.
Here is a video of how the car goes at the moment which also should give you an idea of its handling characteristics.
https://www.youtube.com/watch?v=PeUwsz22pOU
and here is a basic rundown on the car and setup.
It is a 96 S2 Gtst with a steel wheel holset core and about 240kw
Interior
- Stripped interior about 180kgs removed
- 8 point roll cage
Handling
- Bilstein shocks valved for track work
- Springs 350 front 550 rear
- Ikeya formula front upper (front set to 3.2 negative)
- Ikeya formula rear upper (rear set to 1.6 negative)
- Ikeya formula rear toe (pretty sure toe was set to neutral)
- Alloy subframe bushes
- Polly bushes just about everywhere else
- Nismo 2way LSD
- Hicas Lock bar
- Height adjustment set to about stock
- 20mm spacers
- Federal FZ201 semi slicks (about 34psi hot in front and 32psi in rear)
There are other RWD cars running similar setups and power to weight lapping 3-4 seconds faster, now obviously the driver is going to have a big impact here, but looking at there videos they seem to have a lot more corner grip and stability.
https://www.sau.com.au/forums/topic/444856-r33-gtst-handling-advice/
either im blind or you dont mention sway bars.
these are a must.,
if you do have them, soften the front sway a little, it will correct the oversteer.
just my little 2c on the limited knowledge i have.
The initial understeer is what worries me,,,gts-t's don't usually suffer from that. It's certainly not the tyres,,, FZ's are great but your tyre pressures are way different than me,,,I use on a hot day 38 all round and constantly adjust them till I get it. Zebra's on drugs,,,no way is your diff contributing,,,no way. I'm running close to 0 camber on the rears and about 4.5 on the fronts from memory. Artz is right she needs to be lowered,,,big time.
Just do little changes,,,or you will never know what fixed it.
Cheers
Neil.
Yeah hard to recommend changing swaybars when the car is exhibiting both under and over steer.
I found this interesting camber vs tyre pressure info that I will have a go at next track day http://www.turnfast.com/tech_handling/handling_pressure3
I will also lower it a couple of centimetres just a pain for road driving.
I am going to peg rear camber back to about 1 degree if this fixes the rear end grip then maybe i can adjust sway bars to reduce understeer (softer in the front or harder in the back although the links on the whiteline kit seem to only fit in some positions)
You stated the tyre size, but size wheels are you running front and rear? If you're running narrower front wheels and tyres, try running the same front and rear. I think you'll find it makes the handling
a lot more neutral. Also, a bit of toe out on the front will help with turn in and that corner entry understeer. Goodluck, and keep us posted.
You are correct on rim size im running 8" on the front and 9" on the rear.
Interesting I need to get some lighter rims current are about 9ks a piece, will take this into account when i upgrade.
What do you reckon 9" front and rear running 255s?
this counters understeer not oversteer.
Nope, softening a front sway bar will correct understeer..so I just figured stiffening it will help with oversteer...
ED*
though if you look at the graphs below ther eis no clearcut solution really as softening and stiffening can fix it, depending on situation
I have been reading up on this all week man cause the cressy is understeering mid corner, been looking for a solution :P
That's what I would be doing. And then, if it still has mid corner understeer, soften the front sway bar one notch.
thats what i read it as.....why are we all talking understeer now?
Also i dont think rim size is going to make alot of difference, mine felt perfectly stable with 8s and 9s..dont get me worng it will help, but i dont think it is something to really be concerned with.....
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
