Even the OP has stated that it is exhibiting both. I'm no suspension engineer, but you can see and hear that the car has corner entry and some mid corner understeer. And it seems like most of the oversteer is at corner exit. I think a more neutral setup will help alleviate both. But I agree with Neil, by making small changes, I think a lot could be gained. Such as some wheel alignment tweeks i.e. Some more positive caster up front or adjusting the ride height.
  On 25/06/2014 at 9:08 PM, Littlehorn said:
I am going to peg rear camber back to about 1 degree if this fixes the rear end grip then maybe i can adjust sway bars to reduce understeer (softer in the front or harder in the back although the links on the whiteline kit seem to only fit in some positions)
I use the standard factory sway bar links and have had the same problem trying to get them to fit the rear holes on the sway bars. Now I know the front ones are side specific and looking at them I think if you use right for left and visa-versa you can access the other holes. Not sure on the rears but give me a couple of days and I'll confirm it.
Cheers
Neil.
Yeah there is definitely some corner entry understeer and mid corner to exit oversteer. To me personally it feels like the oversteer is more the limiting factor because i cant step on the gas more to increase corner speed and exit speed.
However the entry understeer will be next on my list if i can dial out the oversteer by improving contact patch in the rear then i will work on sway bars and maybe some toe out in the front as suggested.
Have also been doing some reading on this site, very informative.http://turnfast.com/tech_handling/handling_tuningtable
Cheers
Neil.
Interesting please do let me know. I believe there was also a beefed up end links kit i did wonder if you had to get that to get all the adjustment.
Yea but your only running a 2 hole adjustable sway bar,,,I'm of the belief we are talking about the 4 hole puppies which for the links is a different situation all together. Your link is way badly bent and in my opinion would never fit our back 2 holes.
Here's 2 pics of mine and the same sided links will not adjust to the 2 rear holes. We might have to make rose jointed links to make it all fit properly,,,but I will on the weekend work some of it out and post my conclusions.
Cheers
Neil.
Set your centre of wheel to guard height at 340-350 mm. Make sure your bump stops are half the height of std.
Your wheel alignment is way to neutral. Toe out the front to 3mm or so (you may want more) and toe the rear in 1 mm as this will even out on acceleration. You might also find that with these settings and the correct tyre pressure you could stiffen your front bar.
Your set up is very similar to mine, and should be a lot more stable on the turn in and exit.
As Neil said make small changes write them down and keep a log of your opinions of the changes and cars feedback so you have history.
Enjoy.
sounds like its just too high and being a boat :rofl:
Bump steer front and rear. I agree with an earlier comment about this.
Those pretty LCA and tie rod ends don't show true perspective but if they're running on different planes then it's going to do silly things as the suspension goes through its travel range.
Same thing goes for the rear.
Cheers
Neil.
Mine is set to second softest of the 4 on the front i can move it one more adjustment forward. I cant access the front most or rear most.
Enjoy.
Cheers for that i will measure it up tonight so you can all have a laugh!
Should i cut down the standard bump stops?
Hopefully lowering will fix this when i originally set the ride height i did notice the arms were on a slight upwards angle from the wheel to chasis. I assume that level is optimal.
Unfortunately the car came with a fiberglass bumper. Nice and light but it protrudes quite far out the front and actually slants forward so the lowest point is right at the front edge not towards the wheels as with the standard bumper.
The further away (lower) from standard ride height, the more pronounced rear bump steer becomes.
It is countered by installing and adjusting rear adjustable links - the forward/upper ones sometimes referred to as "traction arms".
I never had a bump steer issue and front of my car was lower than most...I had bump stop issues, but not bump steer...
My car had Stock swaybars, all stock suspension arms, bilstein suspension...camber 3 and 1.5 just from lowering, toe set pretty much neutral, I think 1 degree of caster..17 x8,9 and 245/40, 255/40 tyres...It always handled great and exceeded my expectations..I know some people are doing quick laptimes with much the same setup too but better brakes and bigger balls...
my next step was sways bars and some extra caster, but I didnt see the need to do much more to it, it was simple and it worked...Not to stiff, not too soft..
The new owner said he has some issues with the front being too low, because he lives in the bush and has crappy roads though..guess it depends where you drive most and how good the roads you drive on are...But on the track and around Melbourne I never had an issue and my crossmemebr was maybe 120mm off the ground...I know it was just above legal height anyway..
OP was complaining about oversteer hence the comments about rear end adjustments and ride height.
Depending on what is fitted/changed (or not) it is possible to achieve bump steer ie. dynamic toe change as the suspension goes up/down at either end. Altered ride height does affect things.
Open to conjecture but I'd be looking into it if I was the OP. Harry was onto it early in this thread. Investigating and/or fixing it may mean having someone do it for him if he's not sure how.
:thumbsup:
With those spring rates I would be dropping the rear sway bar off totally. If it does roll a little then stiffen up the front bar, though I doubt it will.
Run about -1.0 rear camber with about 3-4mm toe in overall.
There is also an inherent flaw in the rear end design of the r33's when the tire travels from a drooped state to loaded state, the toe essentially becomes dynamic rather then staying at what you set it too statically when doing a wheel alignment.
  • Like 2
Interesting regarding dropping the rear sway bar, I will see how i go this weekend maybe drop of if the rear camber hasn't made a big difference.
Car is set to 340mm front and rear. Alignment set as follows:
Camber front -3.1 deg
Toe front -2.8 total
Camber rear -1 deg
Toe rear 2.5mm total
Running a test day this Sunday at Pukekohe, will post up the results next week.
What are your thoughts on removing vs adding weight into the rear. Is this going to increase or decrease oversteer. Ie if i leave my spare tyre in.
With those alignment settings you usually want 2-4mm toe out on the front, are you saying have 2.8mm of toe out or toe in?
Honestly at this level, dont worry about weight balance yet. If it was me I would be just pulling all the weight I can out to reduce overall weight. R33's are not the best circuit car, they are heavy and cumbersome....but they are fun!
  • Like 1
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
