With those alignment settings you usually want 2-4mm toe out on the front, are you saying have 2.8mm of toe out or toe in?
That is 2.8 toe out on front, and 2.5 toe in on the rear.
Up to now i haven't really been considering where the weight comes from just any weight loss is good. Just considering whether keeping a more even Front Rear weight balance might have a positive effect on handling. But having a read around, as with anything it seems there are pros and cons.
With those spring rates I would be dropping the rear sway bar off totally. If it does roll a little then stiffen up the front bar, though I doubt it will.
Run about -1.0 rear camber with about 3-4mm toe in overall.
There is also an inherent flaw in the rear end design of the r33's when the tire travels from a drooped state to loaded state, the toe essentially becomes dynamic rather then staying at what you set it too statically when doing a wheel alignment.
Plus 1,
After having all sorts of oversteer problems, removed the aftermarket sway bar. Much better. Found it a really hard thing to do. Goes against, what I though I should have done.
One thing that's been skimmed over - tire pressures ?
Maybe have a look at the wear of your tires and also their condition/age and look at trying out different pressures ? Along with suggestions in the thread as the time gap wouldn't just be tires.
You also mentioned there are other cars with similar power to weight etc, but not the cars themselves ? They might just be cars with better balance and chassis from factory...33 isn't the most suited to circuit :(
P.s. Your car looks so much fun to drive, exhausting, but fun!
Once i got my car sticking a bit better, it was less fun to drive haha
Edited by Touge Kyousou
Plus 1,
Interesting might give this a try next time i get a test day down at Hampton Downs.
I must admit the logic of how a sway bar never quite made sense to me. I would think that increasing the weight of the rear sway bar means that the tyre on the inside or the unloaded tyre is being compressed by the sway bar so therefore getting better road contact. Doesnt this mean better rear end grip, Im obviously missing something here.
Tyre wear after alignment changes deffinitely looks more even i will post temps below.
Other car i was talking about is an S14 Silvia, running about 220kws but not as heavily stripped as mine, so it is probably a little lighter and a little less power.
And yes it is alot of fun and tiring particularly since the power steering stopped working properly when i removed the hicas computer.
So a reasonably successful track day at Pukekohe this weekend. The car deffinitely felt more stuck, the front end was very solid the rear is still a decent bit more lose it just seems to get very light in higher speed corners.
Unfortunately not the best comparison because a different track but i am hoping to leave the settings as is and get down to another Hampton Downs track day for better comparison.
I had a play with the pressures and to me it seemed more sticky as i reduced the pressures, so hear are the results:
Front 34psi hot
Temp from inner on the left side
63, 54, 48
Rear 34psi hot
61, 53, 45
So as you can see it looks like less camber would be desirable for this track, I am picking that at Hampton Downs these temps will look more even as the track is less bumpy and has a more grippy surface.
I am just in the process of loading up video will post up this afternoon, but in conclusion it would seem that there has been a reasonable improvement (about 2 seconds part of that is driver confidence) but on this track the camber is to high. Oh and did i mention the car doesnt like bumps which im pretty sure this is down to the lower ride height, it seemed a little more unsettled than last track day through turn 1 which is very bumpy.
Here is a pic of how it looks through turn 1
10379915_10152275893032198_1425255427356
and a decent pic of the car
10355699_10154334993220434_6324121323414
Edited by Littlehorn
that isnt stock height man.
It was at 350mm, now at 340mm.
That pic was also taken coming out of a left hander so a little bit of compression on the right side.
Another interesting thing to note, is that i alwasy seem to lap faster after about 7 or 8 laps, maybe these tyres are just towards the harder end of the spectrum, anyone used the FZ-201s before do they come in different rubber hardness?
A sway bar simply wants to return to its original position. In a corner, it will resist the outside wheel being compressed, and on the inside it will also resist the wheel drooping, meaning less weight on the inside wheel. Both of those things increase the tendancy to oversteer, and give you less exit traction.
I ran my 180SX with no rear swaybar. With 6.25kg rear springs, you don't need a rear swaybar IMO.
Rear bump steer WILL be an issue if you have adjusted camber wth a camber arm and have the stock 'traction' arm. Sorting that out is a time consuming process but makes a big difference. The car won't be so twitchy and will be alot more settled.
I'd suggest making those two changes and the car wil be transformed.
I'd also try 2 or 3 psi lower hot pressures. I ran the FZ201 at 31-32psi hot on my 1250kg 180SX. I also run 32psi hot on my1530kg Soarer with Nitto NT01s.
edit - yes FZ201s come in Medium and Soft. I used mediums. They did change their compounds a while ago though. The original ones were faster/softer. That's the only reason I didn't buy them again for the Soarer. The original FZ201s were great bang for buck. The later ones are not much good.
Edited by hrd-hr30
Here is the footage, https://www.youtube.com/watch?v=C1uOcw1aLUc a little hard to tell how handling has been affected from this footage. The main corner where you want lateral grip is the last corner coming onto the front straight (with the big green brdge over top) this is where i can often feel the rear starting to drift and that wall is awfully close.
I will deffinitely play with removing the rear bar, and will have a look into the rear traction arms as a next step.
Yes i actually realised only in the last session that my pressure gauge was out by about 2 psi when compared to a mates good quality one so will deffinitely go down 2-3 psi and try.
So this could be an issue. Tyres should last longer though. will have a look at the sidewall see if there is any markings about the compound.
On pressures, I'd run them at 32 normally as well (have used both softs and hard FZ201 before with great results)
However, if you are getting faster towards the end of the session that says that they are working better as they get hotter/higher pressure. Or maybe you just get more confident with more laps ;)
As I was saying earlier on, I found the traction arms is what causes the dynamic toe problem with r33's. I had to modify an adjustable one in order to get enough range so I could tune it out so it stays at what we set it at statically. From memory I had to shorten the links threaded body by about 1/2" overall (1/4" each end) so the toe would stay fixed no matter what arc the rear wheels traveled through. That fix and the removal of the rear sway bar made a remarkable difference in rear end grip.
That is something to look at also. Our rear end grip issue has been abit of struggle as we run alot more horsepower then most, however our 33 also weighs about 1600kg with driver and fuel.... :(
Ok so here is a pic of my rear suspension.
Lower arm is standard but the 2 upper arms are adjustable.
So as the rear suspension compresses does the wheel toe in or out more?
There is probably an element of this! The car has only recently been sorted after a few issues with gearbox etc. so i havent had a lot of consistent seat time recently.
We found on our car that it would toe out under droop, and toe in under compression. We were setting toe in at about 4mm overall and as we lifted the car and the wheel would droop the toe was going to +13mm toe out from the static -4mm toe in. Its a huge change, obviously the car wont change that much on the track as both wheels dont extend into full droop while racing, but ideally you dont want any change at all. So the short arm at the front had to be modified inorder to get enough adjustment so we could get the settings to stay where we wanted. However your ikeya formula arms may have more adjustment then ours. We have some cheap items on our car. You will find out if you can cure it or not when you start adjusting it all.
We never really noticed it or checked to see what was happening in this regard until Glen Seton pointed it out to us, apparently its a common problem with most OEM IRS setups or atleast that is what he has found when setting up alot of road car turn race car suspensions for circuit work.
Cheers guys my terminology understanding is also pretty lacking, but i understand now. However it looks like something that would be fairly difficult to eliminate short of building custom pickups and having both arms the same length and mounted parallel.
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 馃槑
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
