better we set this guy's expectations up front first before he decides to spent his $700+ per week trying to make a RB20DET go like a rocket ship, true?
I was once young, naive and silly too.. I spent decent amounts of money on a RB20DET.. thought it was king of the hill.. till I drove a very mild RB25DET and it blew my mind like a girl with succulent lips.
I live in QLD and I'm on my Green P plates.. I'd honestly love to drop an RB25 in it but I'm not sure if I'm willing to take the risk.. Had the idea to shave the engine code off the RB20 and put it on the 25 seeing as the engine basically looks the same and cops wouldn't know what their talking about anyway haha. What do you guys reckon? Is that a big risk in your eyes?
Why not just drive it how it is, block of the bov add a pod filter, to get the fluttering sorta sound, leave the rest stock besides rims maybe a steering wheel etc, being a p plater you don't want to attract the wrong attention, and the rb20 has enough power for a p plater. While ya wait for ya blacks build a mild or wild 2530 or 2630 if ya got that kinda coin. I'm a p plater myself from nsw and I had to get an exemption to drive my 33 gtst.. And it sits in the backyard :(
And never think cops don't know what's going on under the hood, I learnt the hard way, not all of them do but there's the risk you'll get the one who does, if ya wanna get away with it do it right, although I'm legal to drive turbo they still like to pull me over and try and find anything to defect me..
Then it's best you leave your car standard until you're off your P plates.
  • Like 1
for f**ks sake leave the stock BOV set up and air filter.
Pods are a defect did you not know that? P Platers in turbo cars get pulled over more often than anyone else on the road why would you risk it when there is ABSOLUTELY NO GAIN.
flutter sound? who the f**k cares it sounds stupid to anyone who actually knows anything
/rant
/rant
Mate I know this, just saying if he has to change stuff there's some options,
And yes I know pods are a defect but it's not hard to weld up a custom air box to house the pod! Or even buy one.
And altho the blocked of bov sounds stupid, for a p plater new to the scene, to all there's friends it makes an impression, and being a rb20 why care what damage it does
Just like the internal gate screamer pipe, they sound like shit to anyone who has a externally gated one, but to someone who has never owned a skyline/ turbo car before it sounds pretty cool.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
