Hey guys!
Was curious to know, as i'm about to start on my rb25/30 build what things will i be needing to know and was there any headaches i can avoid? Anything that will be needing to be custom made or anything i will need to plug or create into the engine block?
Any infomation on this build will be appreciated.
Thanks guys!
https://www.sau.com.au/forums/topic/444896-my-r33/
Use the later block with the water and oil outlets on the hot side, they also have a flat tensioner area in the front.
Earlier ones have the oil and water outlets cast on the block but not drilled and tapped to take fittings, some also dont have a flat tensioner area on the front where the water pump is.
Block is 38mm taller so expect to extend your piping.
There is a well written detailed write up on it, study it.... http://stevenwelsh.site.net.au/RB30_DOHC.pdf
https://www.sau.com.au/forums/topic/444896-my-r33/#findComment-7323714
