Here in NZ, Rb30's are very hard to come by so its not as easy as $150 worth of parts, when you'd be lucky to pay less then $300 for a bare block :/
I was planning on building it to around 350-400kw, for use on the road and to try get on the track as much as I can. Hoping it will be something I don't have to worry about to much in the longer(ish) run.
And I dont have the standard pistons, only the rods.
So you are pretty much saying if im only after 350kw, stick with std bottom end and put my money into the Neo head?
On the other side of things, by the looks of things the only way im getting a RB25DET Neo head is by buying a complete motor.
Thanks for all the feed back everyone, helps alot.
***EDIT
Ok, so Im thinking I will leave the pistons for now and see if I can get a hold of a 25DET Neo head. As R32Abuser said, the higher compression is better for off boost, which I understand. So my next step is, since I dont have stock pistons I will probably get some forged ones to achieve static 9:1CR and I suppose a bit of piece of mind to know I have a good set.
So should I run with stock rods or get forged rods? As I said im after 350-400kw, but will be good to have something capable of handling more as I dont see my self getting rid of this motor once built and would like the option of going further as years come by.
Well that changes things a tad...
A stock bottom end @350RWKW in a streeter would be fine IMO provided the tune is in check (SAFE!!!). That said, you would be needing to run something in the order of a GT3582 on 98RON to get there which generally would mean high mount. Something which doesn't exactly scream OEM...
400RWKW would be pushing the envelope a bit. Given the "rarity" that I'd imagine RB30's are over there, yes, you would be better off going forged pistons at the least to save you the hassle of sourcing another bottom end. But, like I said above, all it takes is a bad tune, a bad batch of fuel (or both!) and you can kiss either bottom end goodbye...
The Neo head has solid lifters, VCT (over the R32 RB25), more efficient chamber profile (LEV) and a larger range of injectors to chose from. For me, if going through the hassle again, I would take the Neo everytime. But your certainly pay more for them!
Edited by R32Abuser
In the way of tuning, I have access to a tuner, who has lived and breathed link all his life and also owns his own dyno etc.
So I feel I can get a decent tune for sure!
Ok so my plan now is, source a RB25DET Neo Head.
Once ive got the head then I can proceed to get the pistons.
And carry on as I was :)
Im not to concerned if it will take me longer to build using the Neo head, but Im young and can wait haha
Stock rods are fine for his target.
However, by the time you price them up to go with aftermarket pistons they end up costing almost as much as a forged 4340 set from SPOOL or similar...Or at least they did when I went down this path!
http://www.spoolimports.com/spool-conrods/nissan/rb30-conrods/nissan-rb30-conrods
I believe KiwiRS4T meant he should get ARP or similar rod bolts not conrods...
Did you use 2x ARP SR20 rod bolts (which are apparently exactly the same size as RB30)? Had a quick google before and it seems ARP don't sell RB30 rod bolts
Sorry didn't source them myself. I guess whatever fits would be fine.
If memory serves, I believe this is the case. But you'd have to confirm as its been too long!
For some reason when I was pricing everything up, to use the CP pistons I had with the stock rods, I thought the pin size (or another dimension) was different.
Hence, when I priced them up (and a close mate also told me) it ended up costing like $4-600. As per my link above, a set of forged rods cost a touch more. Made my choice easy.
However, it seems I may have been misinformed!
Probably stating the obvious, but the pistons to suit the NEO head will be different (dome or dish) to the pistons suitable for a R32/R33 RB25 head.
So make sure you get the right items! If you dont, your static CR will be off the chart!
This is due to the combustion chamber differences (i.e. size).
Edited by R32Abuser
Yeah I understand that, I will make sure I talk to the supplier and ask for what ones they offer for the 25 neo, for 9:1CP, and double check it here and with a couple of other places to make sure, I could probably ring RIPs.
Another question I have, Will a R33 head bolt onto a R34 Neo Block? Since the Neos are hard to find as just I head im tempted to Buy a complete package, raid what I need and put a R33 head on? And sell off, Would this work? And Does anyone have a clue on what the compression would end up being from this?
Cheers, Liam
***EDIT
Answered my own questions, but have come back with another, what is the compressed thickness of a RB25 headgasket?
CP Calcuator says 8.18:1CP, if the head does fit. I did have to fill the field "Compressed Head gasket thickness" with the size of a head gasket regularly available, now is the advertised thickness the compressed size? Or uncompressed? Just so I can have that information avalible
Edited by N0Vus
Without doing the calcs, that number seems about right. The 33 head has a larger cobustion chamber (more cc's), hence the static CR would be bumped down a bit when used with a neo bottom end.
I believe its compressed thickness but I am not 100% sure. Someone to confirm?
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
