So this is the beginning of my ultra slow build.
The car is a R32 GTST in white, was previously used as a Drift/Track car at Matsuri and various other places and now im looking to "restore" it for road and partial track use.
The car was stripped out and was slowly being converted into a track car, i traded my boat for this and intended on building a Daily thats comfortable.
The list is very long for parts that are needed and work to be done.
Part needed:
A/C & heater Unit (everything)
Wiring Harness (Whole car)
bonnet
front and rear bar
Interior (pretty much everything)
sunroof (whole unit)
bonnet clip
headlights
front indicators
driver side tail light
paint
tyres
all 4 rotors
Pads
FMIC and piping
boost/fuel/various other controllers
stereo
lots of other bits and pieces
Due to work (AV tech so lots of night and weekend work) and money (have a kid) this will be slow going but will be done right and enjoyably.
I have owned a fair few cars in the past, fords, holdens, a R31 S2 silouhette 2x C210s and a stagea RS4 S1.
My Current Daily is the stagea and have a Datsun tucked away in a secret location for my next project.
This is not my first turbo car (stagea was) but this is my first turbo build up so its going to be a little bit of a learning curve.
anyways i hope this is enjoyable and inspires others to build their own personal piece of skyline history. Enjoy!
Build Gallery
https://drive.google.com/folderview?id=0B9IBf0LCEVgMa0lJOTRPT2hFNDQ&usp=sharing
... looks very doable... I'd probably get the chassis checked over before diving head first into restoring it (chassis damage and rust mostly).
.. all these r32 gts-t build threads are really want Another r32 gts-t
cheers mate!
i think there is a little rust in the drivers sill under the side skirt.. :unsure:
the plan is to mechanically check things out and create a job list then strip it down (mostly) and send it to the paint shop/panel beaters and get them to go over it
you should do it, they are a fun little car and a helluva lotta fun!!
  • 1 month later...
So i have been having trouble starting and running the car lately, finally got a chance to look at it (it lives at my in-laws) and it turns out the previous owner cut into the fuel pump wires and made a mess of it, all restored to factory and started first time, and no mis-fire without the tubo connected and AVC-R installed... still a long way to go but another step closer
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
