Do you guys run Dual Wideband Sensors for RB26 ? Is it better than one wideband after the merge at the downpipe?
If you guys do run Dual Wideband Sensors where would you install them? At the OEM 02 location seems too close to the turbo and too hot for the sensors right? And anywhere before the exhaust merges doesn't seem to have the suggested distance away from the turbo outlet.
The best location for the sensor is approx 1 meter from the closest exhaust valve (measured along the central axis of the exhaust pipe) or 1 meter from the turbo outlet ( for turbo charged vehicles)
Edited by etang789
https://www.sau.com.au/forums/topic/444910-dual-wideband-sensors/
whats your thinking for running two? if you want to be more precise with the tune of your car then i'd run individual egt on each exhaust manifold runner.
I will be getting Haltech PnP, and I have been suggested to get the Haltech Dual Wideband – WBC2 setup. Thinking may be it is required or will be more precise on the tune but I dont see how I can find the proper location.
