Ok I have searched so please don't flame me. Nothing has shown up I. My searches with a clear anwser to my question
So obviously car in question s1 33 gtst. Standard rotors. (Fronts are ok rears have a little lip)
Brake pads have squeeled like a bitch when I got them. They have gotten worse (4 - 5 months of owning it). I remember having a quick look and they had heaps of meat so I assumed possibly shit pads it's only ever when it was cold. A few stops and she was fine
Now every light every stop it's loud and getting on my nerves
Now I drive my car pretty hard. And I drift on the occasion. Sometimes at the track. Sometimes at my personal area? If you want to call it that. (This car hasn't seen track yet.)
I don't intend to do any circuit racing or anything that requires the breaks of a supercar
So my question is
Is it worth the money to get slotted and drilled rotors. And if so what ones are worth getting? To suit my needs as stated above
And then the second is obviously what pads
I've always used bendix as far as I know. Trying to get something with minimal dust and ZERO SQUEEL
My budget is pretty mild at the moment. But if it's going to do me a great deal to get something a bit more pricey well I won't tight arse out
But i would rather not waste money on discs and pads that don't help my situation
I also do frequent burnouts
But I'm not the type to ride my brakes down mountains until they are cherry
Thanks in advance and please try not to flame me if that's possible
IBTL
But srsly- slotted rotors are cheap as chips from places like RDA (or eBay) so u might as well.
Get a set of those, decent fluid and some QFM or Bendix Ultimate pads and you will be set.
Braided brake lines if you have extra $.
As for "zero squeal" - make sure u have the anti rattle shims in place, clean everything well when replacing and lube the pad sliders.
Or harden up.
GSL RALLYSPORT... Cheap and have some good gear...
Don't do dumb shit on the street, or at least if you do dont advertise it on this forum... Ever!
Naww dude,
Telling people you are hardcore is so hardcore
I have an erection at the thought of someone drifting a whale on the street.
This cannot be unseen :woot:
Or harden up.
This.
I run Project Mu HC+ pads (a pad that isn't famous for being whisper quiet OR minimal dust) in my Riceline and the only time they "squeeled like a bitch" is when I am bedding them in.
Lol so I get flamed anyways. This is why people don't post on forums anymore....
As for drifting in other places
Blame the government and council I live along way from eastern creek. Oran park wasn't so bad until they canned it.
I live rural on a low salary. Most times it's on my property anyways.
People arnt stupid. I wouldn't be the only person who's cut loose somewhere other then a track. Just tried to give an idea. How much abuse the pads and rotors will see
Also whoever asked again
I googled all last night. Without a straight answer.
Hence this post
Well forget Google and get on the phone to GSL Rallysport and all the answers will magically appear :)
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
