I got a brand new sensor (o2) for my front turbo or front oxygen sensor for my rb26. But after I pluged it in my d jectro power fc went to 5.12v on that channel, and the rear one was at 0.04v. After a while of idling the rear one warms up and starts to move up slowly, but the front one isn't moving at all.
Attached is the photo of the sensor I got brand new. And I'm lost as to why this is happening, all I can think of is there has to be two kinds of sensors for a gtr r32 rb26 motor. High to low or low to high voltage. Im just guessing here.
I would appreciate any help.
https://www.sau.com.au/forums/topic/444920-question-on-r32-rb26-o2-sensors/
maybe incorrect setting on PFC perhaps
r32 titania & r33 zirconia, there's an option in r32/33 pfc to set which one is being used (o2 sensor reg), this needs to be on for R32 and off(+ sign) for R33 gtr
edit - explained
02 REG is needed for BNR32 owners
as the PFC unit for BNR32 and BCNR33 is the same unit but the BNR32 has titania 02 sensors and BCNR33 has normal 02 sensors.
the BNR32 needs to be set as registered to make them work as titania sensors properly. Otherwise with it off the PFC assumes they are BCNR33 style 02 sensors.
This is covered in the FAQ
apexi's official answer;
There is a difference in the O2 sensor for these vehicles. (With or without internal register)
After tuning, please check () "O2 SENSOR REGISTER" for BNR32, and NOT for BCNR33.
* It may be different if the O2 sensor is modified and/or changed.
Wow. Im lost now. Where do I find the with or without internal register feature. ???
I will look over the FAQ section and see if I find anything.
Whats a titania o2 sensor??.
And whats the right part numbers for a sensor of that type.?? If you have it. I think im running normal sensors right now. The voltage starts about 0.04 and as the car runs they go up slowly.
Can someone expain this in layman's term. Lol
:blink:
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
