Hi all, I have a problem that is both making me lose hair and sleep, and weight as I have to walk everywhere! I recently changed the injectors of my car over (2 of the originals were leaky) everything was good for a day and a half, untill the car stopped dead on me on my way to work. got the car towed home to sort it out, but the no start problem is still there.
So this is what is going on.... when I pull out the CAS, and turn it the injectors can be heard clicking, the fuel pump is working, but the strange thing is that the only good quality spark comes from cylinder 1, all other coils give a weak spark, and somewhat erratic as they dont spark regularly compared to the first, i swapped the coils arround, same thing still good on number 1, I have tried a new ignitor, put new plugs in, can smell fuel in the exhaust after cranking for a long time, even teamed up my freshly charged battery with a jump starter pack, seems to almost want to go (prob cylinder 1 doing the right thing), but wont. Speed of cranking does not sound any different to normal, and timing belt has not moved over any teeth, If it is of any consequence, I noticed that the tacho does not move when cranking.
Before I delve into the sea of wiring I figured Id see if i can get some pointers from you, I have checked earths quickly, and they seem ok, but have not gotten arround to testing continuity of wiring to the ECU, when the car stopped I had only been driving for 2 minutes, and was not giving it a taste of my right boot prior to stoppage.....
Any help, ideas, oppinions etc. would be greatly appreciated, before i turn into skinny zombie kojack............
cheers and beers,
Matty.
As there seems to be spark issues obviously look into that first. As per above I'd look at the coil pack harness, they get cooked after many years of use and can snap wires especially if you played around with them while doing the injectors.
If the spark side is actually ok then possibly could be something to do with high/low impedence injectors? Did you change all of the injectors or just the leaky ones? If you changed all to high impedence and didn't get rid of your resistor then that may give you troubles.
Good luck!
ok, so it turns out my brain doesn't function particularly well on 4 hours sleep, ignition is all ok, turned out i was turning the CAS the wrong way, so spark side of equation is all good, I guess the next things on the list are to check fuel pressure, and the compression, unless there is something else I should look towards, please note, I have tried everything with each set of injectors installed, and these replacement injectors are factory r34 gtr injectors, which research shows me are interchangable with r32 injectors, but this info has been from on-line sources, so.....Anyhoo, thanks for the input, any more thinking from anyone else, so I dont have to use my dodgy brain, is again greatly appreciated.
Matty.
Just to give this closure, I performed a compression test, results left a bad taste in my mouth, #1 75psi, #2 115psi, #3 120psi, #4 40psi, #5 40psi, #6 40psi, even though the gauge was a cheap one, and possibly far from accurate, the differances can not be argued with, test was performed multiple times, with not much variation of numbers during each attempt, throttle down, fuel pump unplugged and a fully charged battery.....
This has left me wondering WTF has happened? car started easily before that fatefull drive, did not seem to turn any different from any other day, as I said in the first post, I was not wringing the things neck, hell it was still warming up, and I do preach mechanical sympathy at these times, I guess a leak down test is the next step, Any clues as to what may have occured to turn a once healthy engine into one that will not start due to catastrophic compression loss??? Time to pull the AE86 out of mothballs and get it regoed, sick of this walking caper...... Alternatively, anyone got a healthy rb26 bottom end for sale around Newcastle???
Thanks for the help guys, I guess only excessive alcohol consumption will ease my pain from now on!!!
Matty.
unusual compression test readings indeed. as you said the differences are whack.
Back 3 line up even though showing extremely low but 0% difference. 2 and 3 acceptable difference. #1 out by itself.
Correct - Excessive alcohol helps. Look forward to finding out why also
Judging by your number of posts you haven't had it long either. That's sad :(
Who knows could be something simple, so don't drown in booze just yet
Edit:
Blown head gasket for the back 3 ?
Spark firing issue
Edited by Sinista32
Same low pressure readings for adjacent cylinders USUALLY indicates a leak between cylinders. It would take a SERIOUS overheat to warp across 3 cylinders like that.
There are a few other possibilties though.
Lack of compression in the areas between the cylinders due to:
Original headgasket & head bolts. Years of heat up, cool down, head bolts don't like that, & will eventually give up.
Higher boost levels with original gasket & bolts.
Q: Which 2 injectors did you change? When they were leaking & when trying to start the engine, did it ever sound like it hydraulic locked (rrr-clunk)?
Have you had the rocker covers off to check the camshafts? Has 1 snapped? It wouldn't be a first time.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
