Thanks mate!
No specific plans to be honest. Just a few things I'd like to do.
So, after the trackday I went over everything again. Found my gearbox was making a nasty input bearing noise, so took it down to award. After a chat to Terry, he said it was nothing to worry about, and that the noise would probably drive out in a few hundred kms on the road. I suspect the ATF I was using in the box was too thin and not providing enough protection in high G areas, so I refilled it with Redline Shockproof light. Again, I can't complement the gearbox enough. People say they are weak, but this has had so many track days now, and looking back on the vids, a couple of times where it should have gone pop but hasn't! Driving style has a lot to do with it I think.
I've installed a power steering cooler, as I think the PS was getting pretty hot. I grabbed a small PWR auto tranny core from repco and plumbed it in, and ran a duct to it. Pics will be below. Pretty easy to setup, and not very expensive. It's just mounting it and finding the space!
I've got to get the dump pipe off, and it's got a couple of small cracks on one of the supports, they need a bit of weld.
I want to investigate water cooling for the wastegate. It has a tial 44mm on it, with the ports to water cool it. I want to do this mainly for reliability. But I'm not quite sure where to get and return the feeds to.
I also want to make up some deflectors for the front brakes, as they were getting pretty damm hot and glazed the pads. I never lost brakes, but it is clear that they can work better then what they were.
Finally, I might have my hands on some more slicks to try out after the Sydney 500. Should be a set of Yokos I can get my hands on. The Michelins have been epic, and are the Rolls Royce of slicks, but they are getting pretty worn now (have a look at the front right!).
  • Like 1
  • 2 months later...
You'll shit in an 11 if you can get it off the line.
Probably, my best 60ft was a 2.0
It's a bit of a pig to get off the line. This is on federal RSR 235/45/17 at 25psi. Doubt I'll take it again, I just don't want to smash the gearbox.
That brake squeal though
Because Racecar! Actually, I was bedding brakes in down the slow down area :D
  • Like 1
  • 1 month later...
Trackday put on by RTDC at SMSP south circuit. Had unfinished business since I was unable to take my place at the 2014 SAU trackday.
Had a little hiccup where some silicone intercooler pipe decided to burst due to heat and pressure, but fortunately some guys at the track helped me out with leads, and after a short drive, it was back in business without missing a session. Will make up some heat shielding to protect it for the future.
Rear tyres turned out to be pretty diabolical, so I couldn't even get full boost into her. Definitely due a new old set of slicks. In comparison, on full power out of the hairpin on the Brabham circuit day I could get power down pretty easily. On low boost it just burst into wheelspin.
Nevertheless, I got a PB (by 3.5 seconds no less!) of 1:04.1. Have no doubt on some fresher tyres that would drop into the threes.
  • Like 2
I heard the dyno ate your next pair of slicks, and the set from the F1GP will be mine... suckah.
Lol, no, someone who wanted to put on a "good show" for the cameras cause his ugly mug is gunna be on the telly ate up my new pair of slicks down to the belts!
I'll have my grubby little hands on something... ;)
  • Like 1
  • 3 months later...
Well, long time since updates, so away we go!
I noticed the rear pads were getting pretty hot, so I did something I should have done a long time ago. Cut the stone guards off it. I know, exciting right!
On to better shit.
I wanted to get it looking a bit tougher, and I went through a phase of looking for Type X bits for ages, but never bothered getting anything. I liked the look (everyone does compared to the earlier front end!!) and it gives me heaps more air to play with for ducting. Well, I found a OEM front bar, AND an OEM Lower lip for sale round my neck of the woods. Went for a drive, cash changed hands and boom; it was mine :)
Needed a bit of work, had some random holes in it, bit of a ding, and was silver, but had all the metal to go behind it. Well, something to work on!
So, I went to work - fibreglassed the holes, and a crack in the lower lip. Bogged up the dent, and filled the holes,
More to come in a bit :)
  • Like 1
So being an hugely experienced painter (having painted two bars, and a roof in my life...) I decided to do me own work. DIY mechanical is one thing, paint and panel is totally another!
Anyway, Bar and lip went into primer just fine
And then all these bits came along to make it look a bit more complete.
They're from JSAI Aero, and seem to be of decent quality, and test fitted ok.
Finally, a bit of a sneak peak ;)
Still have a fair bit more paint work to do, so another couple of weekends probably before its time to roll.
Got to get the electronics sorted for the new indicators too. The LEDs need resistors, and the wiring needs a tidy up.
  • Like 3
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
