Hi all just having a look through a few different things to find out how to tell if you car has a LSD or not.
I currently have a 350gt premium coupe auto and just went for a quick spin thought I might burn a bit of rubber had a quick look back and I noticed twinnies so I'm assuming it has a LSD
sorry if seems like a noob question but I thought I'd ask
https://www.sau.com.au/forums/topic/444934-lsd-question/
usually it was only on the 6MT or if the 'sports' option was selected.
Jack one rear wheel off the ground, remove the handbrake and put it in Neutral (with suitable chocks under the front wheels of course), if it has LSD, the wheel will need more effort to turn by hand and you won't be able to turn it very fast, if it has an open diff, it will turn fairly easily.
Or, jack up both rear wheels, (again in N with handbrake off), turn one wheel, if the other one turns the same direction, it has an LSD, if it turns in the opposite direction, it doesn't.
Edited by sonicii
https://www.sau.com.au/forums/topic/444934-lsd-question/#findComment-7323590
Oh I feel like an idiot...I don't know why I didn't think of this :/
I shall check the code as well!
Thanks heaps guys appreciated
https://www.sau.com.au/forums/topic/444934-lsd-question/#findComment-7323695
Mine was auto with an LSD - confirmed both by code & wheels off the ground and both turn the same way.
You can go to the following site - http://nissan.epc-data.com/ & enter the Japanese VIN (mine was cpv35-5005xxx - xxx is numbers changed to protect the guilty) and it will show you what options were fitted at the factory. If you hover the mouse over each option code you will get a description, mostly in English. Mine had the following option codes:
CLAS8 - Premium spec
DWHL8 - Shows "18(-0411)/19(0411-)インチタイヤ+ aluminum +ビスカスLSD" which google translate says is "18 (-0411) / 19 (0411 -) inch tires + aluminum + viscous LSD"
GLSSW - Privacy Glass
TELV2 - TV/Navigation (DVD)
Thanks to Rob101 who originally posted the link above.
  • Like 1
https://www.sau.com.au/forums/topic/444934-lsd-question/#findComment-7324164
  • 1 month later...
  • 2 years later...
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
