Lsd Question
Hi all just having a look through a few different things to find out how to tell if you car has a LSD or not.
I currently have a 350gt premium coupe auto and just went for a quick spin thought I might burn a bit of rubber had a quick look back and I noticed twinnies so I'm assuming it has a LSD
sorry if seems like a noob question but I thought I'd ask
usually it was only on the 6MT or if the 'sports' option was selected.
Jack one rear wheel off the ground, remove the handbrake and put it in Neutral (with suitable chocks under the front wheels of course), if it has LSD, the wheel will need more effort to turn by hand and you won't be able to turn it very fast, if it has an open diff, it will turn fairly easily.
Or, jack up both rear wheels, (again in N with handbrake off), turn one wheel, if the other one turns the same direction, it has an LSD, if it turns in the opposite direction, it doesn't.
Edited by sonicii
Oh I feel like an idiot...I don't know why I didn't think of this :/
I shall check the code as well!
Thanks heaps guys appreciated
Mine was auto with an LSD - confirmed both by code & wheels off the ground and both turn the same way.
You can go to the following site - http://nissan.epc-data.com/ & enter the Japanese VIN (mine was cpv35-5005xxx - xxx is numbers changed to protect the guilty) and it will show you what options were fitted at the factory. If you hover the mouse over each option code you will get a description, mostly in English. Mine had the following option codes:
CLAS8 - Premium spec
DWHL8 - Shows "18(-0411)/19(0411-)インチタイヤ+ aluminum +ビスカスLSD" which google translate says is "18 (-0411) / 19 (0411 -) inch tires + aluminum + viscous LSD"
GLSSW - Privacy Glass
TELV2 - TV/Navigation (DVD)
Thanks to Rob101 who originally posted the link above.
  • Like 1
  • 1 month later...
  • 2 years later...
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
