Hi all,
I've recently had some work done to my r32 gtr, (larger injectors, boost increase, adjusted cams) and have had a retune (nistune).
I've driven the car and competed in a hill climb, and all is well, however all of a sudden was unable to start the car.
After investigating- turns out the injectors are high impedance not low (was advertised as direct replacement - I guess that doesn't mean anything!). I've now removed the resistor and it's now running again.
So my long winded question is - would it need to be retuned now the injectors are getting correct ohms/power?
Or doesn't it make a difference? Was strange how it was running well for a week....
This is weird. I wired a power fc for a gtr to work in a gtst. I got it and it all worked good. Of course I had no vtc. What I learned was that all rb ecu wants to see a high impedance resistance. The rb25 are high impudence injectors and the gtr rb26 are low but the gtr has a resistor pack to boost the low impedance injectors to a high ohm reading. So in short all ecu's wants to see high impedance signal. I really think nissan thought peopel wouldn't get this. Lol. If you have high impedance injectors on a rb26 ecu.?? Just get rid of the resistor pack (rewire) it and you will be ok. From a resistance stand point.
Edited by MJTru
Um....Marcus....that's exactly what he said and did.
OP.......Yes, retune. The opening behaviour of the injectors will be different without the resistor - effectively the latency will probably be changed the most - so it will affect light load mixtures more than high load, but still worrth doing.
Awesome - thanks for the help guys.
Such a pain in the backside - as it only just came back from the tuner!
So are the injectors slower to open? I'd hate to be driving it running too lean...
Yes GTSBoy I agree thats what he was saying. I may have missed somthing tho. A rule of thumb for me is. Any mods to fuel or air should be mapped and retuned. Intresting info GTSBoy as I never thought it would affect the injectors the way you mentioned it. I will be looking into this. Also intresting to know it would make more difference in the down low area. Hmmmm
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
