V28VX37 Posted June 28, 2014 Share Posted June 28, 2014 (edited) Hi guys, Has anyone replaced their exhaust middle muffler with a resonator? If you did, what happened to the noise levels? I've got an R34 GTT sedan with an R33 HKS Super Drager (the one with the massive rear muffler) modified to suit, but the middle muffler is sitting really low and regularly scraping. I'd like to replace it with a resonator (to run under the transmission tunnel) but I like the relative quietness of the exhaust system as it is, so I don't really want to make it louder... Also, what catalyser would you recommend to flow 300rwkw? Needs to bolt on to 3" flanges. I'm thinking a 200cpi metal cat of some kind. I've got an X-Force ceramic high flow currently but it's suspected of restricting flow. Thanks! Edited June 28, 2014 by V28VX37 Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/ Share on other sites More sharing options...
Ryno Posted June 28, 2014 Share Posted June 28, 2014 I use a Venom Cat with 5" body, that should allow you to hit that power goal. See link... http://www.ebay.com.au/itm/3-Nissan-VENOM-High-Flow-Cat-Skyline-R32-R33-R34-GTST-GTR-S13-C33-A31-/251462134106?pt=AU_Car_Parts_Accessories&hash=item3a8c4fa95a As for replacing the muffler with a resonator, it really depends on the quality of both. But typically a resonator should muffle the sound reasonably well at low RPM's, though at higher RPM it will change the note but not muffle the sound as well as a standard muffler. I'm currently looking to do the same with my car - I've found these resonators which seem to have pretty good reviews that I'll probably go with: http://www.ebay.com.au/itm/Vibrant-ULTRA-QUIET-Resonator-3in-inlet-outlet-x-14in-overall-length-/281208154580?pt=Motors_Car_Truck_Parts_Accessories&hash=item41794fe9d4 1 Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7324048 Share on other sites More sharing options...
V28VX37 Posted July 3, 2014 Author Share Posted July 3, 2014 Thanks Ryno! Any other recommendations for resonators or cats? Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7329403 Share on other sites More sharing options...
scotty nm35 Posted July 3, 2014 Share Posted July 3, 2014 I use 200 cell 5 inch cats, similar to the Venom ones, they flow over 400kw. Not cheap though, around $200, and they don't have the flanges welded on yet. The Venom 100 cell ones come with the flanges already welded in the correct place, and for a very reasonable price. I would buy one of them seeing you already have the cat back, they should flow even more, but I believe 100 cell isn't 'Legal' afaik. Resonators are crap. Perhaps you can just get the muffler tucked up a bit more? Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7329422 Share on other sites More sharing options...
wolverine Posted July 3, 2014 Share Posted July 3, 2014 Venom do 200 cell ones too last I checked (which was a while ago) if this is important to you. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7329462 Share on other sites More sharing options...
AngryRB Posted July 3, 2014 Share Posted July 3, 2014 mine sounded just right with a 100cell 4inch cat, 3 1/2inch system with 3 1/2inch jap resonator and a 3inch Xforce muffler, that's all, sounded like quality and just like a well breathing engine not a shit loud muffler and crap breathing engine Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7329481 Share on other sites More sharing options...
scotty nm35 Posted July 3, 2014 Share Posted July 3, 2014 Venom do 200 cell ones too last I checked (which was a while ago) if this is important to you. That would be the best option then, and will flow more than enough for OP. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7329493 Share on other sites More sharing options...
V28VX37 Posted July 5, 2014 Author Share Posted July 5, 2014 Thanks guys! I've just contacted Venom to check availability and price of the biggest 200 CPSI bolt-on cat they have with 3" flanges. ...Resonators are crap. Perhaps you can just get the muffler tucked up a bit more? Good idea, thanks Scott. I just had another look at it and there's at least an inch and a bit of space above the cat & mid muffler, I better take it to an exhaust shop. Just out of curiosity, why are resonators crap? Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7330835 Share on other sites More sharing options...
KiwiRS4T Posted July 5, 2014 Share Posted July 5, 2014 I think there is a large variety of resonators on the market and the materials used and method of construction obviously play a part in how well they work. I have a 5inch 100 cell Venom cat, a 3in resonator about 500mm long and a 3in Japanese muffler ( had a job to find one that was 3in right through - many are stepped down to 2 1/2 in just before the tail pipe for some reason). This system sounds good and is right on the edge for legal loudness. This is measured at 3000 rev/min and its is in fact quite a bit louder at 6 - 7000 rev/min which is why i keep the revs down around town! Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7330910 Share on other sites More sharing options...
butterfly effect Posted July 12, 2014 Share Posted July 12, 2014 I can supply a 3" resonator 5" diam. or 3.5" bore , 4.5" diam. 409 s.s. perforated tube with expansion joint , packed with inox (high temp.Both 400 mm long. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7337114 Share on other sites More sharing options...
Manuel Kasko Posted July 12, 2014 Share Posted July 12, 2014 I can supply a 3" resonator 5" diam. or 3.5" bore , 4.5" diam. 409 s.s. perforated tube with expansion joint , packed with inox (high temp.Both 400 mm long. You really should contact admins and get a dealer membership going if you want to sell stuff. Sounds like you sell some quality products at good prices. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7337557 Share on other sites More sharing options...
butterfly effect Posted July 16, 2014 Share Posted July 16, 2014 I am but a small fish in a big pond but my mufflers are designed to give the best possible performance without being influenced by other requirements such as sacrificing performance for cheapness. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7341172 Share on other sites More sharing options...
niZmO_Man Posted July 16, 2014 Share Posted July 16, 2014 Good for you. You're still advertising your products and you are running a business - pay up like everyone else. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7341652 Share on other sites More sharing options...
Manuel Kasko Posted July 17, 2014 Share Posted July 17, 2014 Good for you. You're still advertising your products and you are running a business - pay up like everyone else. Agreed with Ravi, we are all for products like yours but you have to do what everyone else does and pay for the right to advertise. Hypergear is a small fish in a big pond and now he has a huge following on SAU, however he pays to advertise on here just like every other business. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7341727 Share on other sites More sharing options...
zebra Posted July 17, 2014 Share Posted July 17, 2014 I am but a small fish in a big pond but my mufflers are designed to give the best possible performance without being influenced by other requirements such as sacrificing performance for cheapness. Like using 409 stainless so it rusts just like mild steel? Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7341729 Share on other sites More sharing options...
butterfly effect Posted July 17, 2014 Share Posted July 17, 2014 409 rusting like mild steel. I don't think so. I don't know where you get your information from but I would be changing sources. Link to comment https://www.sau.com.au/forums/topic/444960-replacing-middle-muffler-with-a-resonator-best-cat-r34-gtt/#findComment-7341852 Share on other sites More sharing options...
