So I've blown my 380xxxkm RB25DE (just a ring or two) and think it's time to move forward on a build I started a year ago, my RB20.
I purchased most of what I needed and my friend has completed 90% of the head porting.
Poncams are what I'll be using as I already have them in my 25,
Tomei spirngs,
ARIAS 81mm forgies,
cometic 1.3mm MLS gasket,
SARD 650cc injectors,
NISTune,
NZ steam pipe low mount manifold,
ARP studs main and head,
Walbro 255lph in tank pump,
Maxima airflow meter (cheaper than Z32 and good upto 500hp),
Oil cooler,
6kg flywheel.
Bearings are something I'm waiting to purchase until after the crank is all measured and hopefully gravy.
I also haven't decided which turbo to use just yet but I am leaning towards the KINUGAWA TD06H 20G 8cm. It's internal gate and I want to retain a low mount. Also it's cheaper than most.
The thing that will be interesting with this motor, I think, will be comparing it with similar 20's that aren't ported. People just don't bother very often (with building 20's and/or porting them).
You'll also notice there is no mention of rods. They will be standard. Honestly the only reason I have forged pistons is because the motor like my 25 has blown rings, so while I'm in there I may as well enlarge the bore.
Intercooler is also something I'm not sure about, but I am leaning towards the PWR vertical core setup so the pipe work will be short as possible because I am retaining the standard intake plenum. Possibly a PWR radiator as well.
The goal is anything over 200rwkw and to see the difference in boost required in comparison to a standard head.
Pictures will come when there is something to show, an RB20 block looks the same as the next.
Any constructive input would be great :)
https://www.sau.com.au/forums/topic/444962-200kw-rb20-build/
200rwkW is easy as. So you should be aiming for 240+.
The porting coupled with the cams and the big turbo will likely make it a little soft down at the bottom end unless your porter is a guru who can really make it work without opening it up much at all (cross section wise). Shouldn't want to open it up anyway - hopefully he knows what he's about and has worked on the bowls, short turns and the low lift flow across the seats.
You are correct about rods. RB20 rods are tough. I would prep them myself though, rather than leave them comletely stock.
Consider a Hypergear turbo - even if you want a TD based turbo, consider a Hypergear.
Don't use the shitty vertical tube intercooler core. They have good low pressure drop but terrible cooling efficiency compared to a longer tube core. I have posted on this extensively before, so you could search my opinions if you like. Don't worry about the longer pipe runs - lag courtesy of longer pipes is a bit of a myth. Just buy a decent return flow core.
  • Like 1
You may be right, 240 is achievable it's just that I'm being conservative when saying what it will make so I'm not disappointed.
Yea it will very likely act like a 2 stroke power band wise, which is fine. If it were for grip I'd aim for a buff midrange. But it's drift and the peaky curve is suited to the way I drive.
He's a kind of backyard guru. I'm very confident in his abilities and knowledge having seen some of the heads and motors he's put together over the years.
Had a look at hypergear today and the ATR43SS1 might be the way to go. Bonus is it's an Australian company.
Ah, ok then. Will avoid the vertical core. Does make sense that the cooling efficiency is dismal in comparison to a cross flow.
Cheers man :)
Yea some retard had to give a 20 a go. Didn't realise it would be me. Should have just built the 25, but I digress.
The Nistune was chosen because for what I'm after I couldn't see the point in spending another thousand on something like a microtech. But also I was planning to use it for my 25DE until it blew so I already had it just chilling in the parts pile. Not to mention it retains the factory cold tune so it will actually start and keep running first time it fires, which is nice.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
