You should use the rb26 harness. If its a r32 harness its better as all the plugs are the same as the r32 gtst. You should use the body and engine harness. It just works like if the car was a r32 gtr, the only thing that won't work will be the fact that the r32 gtr has the 3 gauges at the middle of the dash. You will also need a moded rb26 oil pan with the front diff removed. You can contact racefab, and get one but it isn't cheap. Or you can mod a rb25 oil pan to fit the rb26 which takes a bit of creative thinking, but can work if your a good metal worker. Thats about it I would say. Well major issues that is. Im not to sure how the engine mounts will line up as I did it to a r32 gts4 and it dropped right in. I hope it was helpful info. Update me please on your progress.
Edited by MJTru
