May be of interest to fellow petrol heads. If you haven't watched this it's being live streamed from about 6 pm tonight. Absolutely everything is there including Jay Kay's Italian green La Ferrari to Craig's green eyed Falcon Supercar running up son of rajab March's driveway.
http://grrc.goodwood.com/#/0
https://www.sau.com.au/forums/topic/444986-festival-of-speed-live-stream/
    • Holy hell! That is absolutely stunning! Great work!!!
