No where on google sau or any skyline forum has anything to do with adjusting the window
So my dilemma
When I rolled my windows up after installing a new door shell the window would wind up and not slide into the seal but pop on the outside
I noticed there's adjustment on the front bailey channel 12 mm nut on a stud that's adjusted with a flat head
There's 2 on the rear bailey channel
2 felt guides
And 2 height guides
And another too centre to the door 10mm nuts not sure what these do
I've fiddled around for the good part of 2 days
Finally got it so the door closes properly with the window up ( sliding into the seal properly
Then before I put the door trim on. I tested putting the window up while the door was shut. Lucky I did because once again it was hanging too far out at the top and not going into the seal
After further tinkling I sorted that out
But now when I drive it won't slide in properly. Only when I'm stopped
More tinkling
And I've got it anything 60km and under on a flat road it works fine but any faster or a slight bump won't let the window slide into the seal
About to burn the car. Does anyone have the slightest clue to what I should be actually adjusting?
Or can anyone tell me what each adjustment does. This will give me a better indication as to what I need to focus on
Currently randomly moving different ones
https://www.sau.com.au/forums/topic/444996-window-adjustment-help-asap-please/
