Sr housings wouldn't fit with custom dumps?
no the sr20 has the studs in the manifold and the rb26 has them in the turbo and the housing sizes are substantially bigger
It could be done with custom manifolds, lines, dumps, fittings, drains and etc
Fark, I didn't think there was that much difference :(
That is an interesting idea, that Hawkins dude put -7 comp housings on to -5s and got decent results with it and with the Billet wheel should be even better :)
Realistically he got dash 5 results...
Why dick around with baby T67's?
5D6F0B0E-830B-4ECC-8F2B-8D8F937B5A1A_zps
Twin T88's!
Sure they are Twin T88's? They look more like T67's or TD06-25g
TU2868RHTA Upgrade customer's GT2860R or RS to a 68mm HTA billet compressor wheel $700.00
I just jumped onto the FP site. The 68 mm wheel is $700 per turbo.
In regards to the rear housing issue, would there be any advantage of opening up the gate hole? Something like the XR6T boys do with their stock turbo's.
thats to fix boost control issues
Twin T88's!
Yeah!!! They're td06 25g's. I nearly bought them years ago (greedy/trust art-coffee table).
....after saying it in jest, I wonder how 3 N1 turbo's would go?
Crazy twins you say?
I could probably squeeze both Olsen's in the engine bay
Edited by XRATED
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
