Take the 26 sump to a decent fabricator and ask him to cut the diff off it and weld it up. The 26 sump has quite a bit of strength to it. While they are at it put a decent extension on it to your oil side of things is sorted. If your in Sydney Performance Metalcraft know what to do with it :)
While the engine is out i would also put a decent oil pump on it so you dont have to worry about pulling it out again any time soon
https://www.sau.com.au/forums/topic/445010-rb26-conversion/#findComment-7327843
The 25 sump and oil pan doesn't just fit straight on. There is some fabrication that needs to happen. After you bolt up the 25 oil pick up. The oil pan wont just go on. After you figure out how to get it on you will notice that the oil pan is hitting the base of the oil pickup. Then if you want you can grind the pickup base which I dont like to do because it can lead to oil problems later because of how much you have to grind off to fit the oil pan on the block. When I did it I simply modified the rb25 oil pan in that section. I heated it up and shaped the side in a round fashion to clear the oil pickup base. Then if I remember its still has one bolt I had to sacrifice which was no big deal as the sealant (silicone) took care of that.
What I would do if I did it again is as mentioned above use the 26 aluminum oil pan and cut the diff off and weld in parts that needs to be filled in.
Go on RaceFab and look at how they did it on there site. Or just buy one from them.
https://www.sau.com.au/forums/topic/445010-rb26-conversion/#findComment-7328565
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 🥲
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
