Firman Posted June 29, 2014 Share Posted June 29, 2014 Hey I have this r33 gtst which i bought about 2 months ago from a mate. It had bits taken off the engine so i got another rb25det which has done like 90000km and slapped it in. It was running fine in the other car and when i got it into my car it was running well. I was driving only a day ago when it started to cough and splutter and run real bad! If i tried revving it, it would stall so i took off the afm and it ran abit better but was stillrunning really rich. I change the coils and cleaned the injectors looks like uts getting too much fuel. Would the afm be the main issue? Its lightly modded fmic, 3 inch exhaust and pod filter which is about it. Help me out guys really need to get this running cause i was planning it to be my daily as just got it running ahahah any help will be appreciated Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/ Share on other sites More sharing options...
Firman Posted June 29, 2014 Author Share Posted June 29, 2014 And also when i plug afm it just stalls. Its obviously the afm sensor but would there also be any other factors of running bad? Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324935 Share on other sites More sharing options...
Ben C34 Posted June 29, 2014 Share Posted June 29, 2014 What? You said it yourself the afm is a problem. Replace it or clean it and see what happens. Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324938 Share on other sites More sharing options...
Firman Posted June 29, 2014 Author Share Posted June 29, 2014 Yeah i cleaned it still runs bad Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324942 Share on other sites More sharing options...
Ben C34 Posted June 29, 2014 Share Posted June 29, 2014 Replace it. Check for leaks in pipework. There are heaps of reasons why it could run bad. All are a guess based on the little information you have given. Go ask your mate to fix it. Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324959 Share on other sites More sharing options...
scotty nm35 Posted June 29, 2014 Share Posted June 29, 2014 Either replace the AFM or resolder the pins inside, they often get dry joints where the plug pins meet the board, especially if you play with the wiring/plug. Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324967 Share on other sites More sharing options...
Hadouken Posted June 29, 2014 Share Posted June 29, 2014 Hold on here. Did you check intercooler pipes and all vacuum lines? It sounds like you have a boost leak hence why it started dumping heaps of fuel and stalled. Unplugging the afm puts it in limp mode. If however you do not have any loose pipes or cracked boost lines then yes replace your afm. But check the cheap/free stuff first Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324986 Share on other sites More sharing options...
Firman Posted June 29, 2014 Author Share Posted June 29, 2014 Lol my mates hopeless :') was asking you guys cause youre more familiar with the skylines than i am! And will do mate ill check the intercooler piping, etc tomoz after school! And i might aswell buy a z32 afm while im at it or should i just get an original for the time being? Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7324994 Share on other sites More sharing options...
Hadouken Posted June 29, 2014 Share Posted June 29, 2014 z32 = tune Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7325002 Share on other sites More sharing options...
89CAL Posted June 29, 2014 Share Posted June 29, 2014 Simple. Fix/Replace AFM first and then you can start diagnosing other problems And when Hadouken says Z32 = Tune, that also means getting an ECU/Piggyback to enable it to be tuned. You can tune a different AFM into stock computer Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7325007 Share on other sites More sharing options...
Ben C34 Posted June 29, 2014 Share Posted June 29, 2014 And when I said check for leaks I mean pressure test for leaks. Google it Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7325009 Share on other sites More sharing options...
Firman Posted June 29, 2014 Author Share Posted June 29, 2014 Yeah just realised about the z32 afm :') yeah will do a pressure test mate cheers for the help will tell you how it goes when i get to it! Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7325013 Share on other sites More sharing options...
Firman Posted June 30, 2014 Author Share Posted June 30, 2014 solved it today! checked maf sensor and cleaned again and connectors and it worked abit better still shit then checked all hoses and found the one that connects to the top of the turbo came off! mustve been when i floored it down the road for the first time :') still runs a lil rich though but alottttt better than before im guessing my timing could be out considering the motor has only been in for about 2 weeks now so ill get the timing done! cheers guys for the help!! Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7326318 Share on other sites More sharing options...
Hadouken Posted June 30, 2014 Share Posted June 30, 2014 Good work. Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7326399 Share on other sites More sharing options...
Hadouken Posted June 30, 2014 Share Posted June 30, 2014 Check your plugs now. They are probably black Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7326401 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 1, 2014 Share Posted July 1, 2014 Check your plugs now. They are probably black just take it to a drag strip, clear it out Link to comment https://www.sau.com.au/forums/topic/445011-r33-running-rich/#findComment-7326877 Share on other sites More sharing options...
