Sau Vic Tech Night: Discussing E85, Thanks To Wolf Motorsport & Sabbadin Automotive
Can someone film the night for us NSW people :)
We are working on getting a video done, providing all goes well will post up once completed after the event.
  • Like 1
Fantastic turn out tonight! Thanks heaps to everyone, especially Robbie from WOLF Motorsport & Rob from Sabbadin automotive :)
  • Like 1
Heaps of great information and things to look out for :)
There were plenty of pics taken, but unfortunately no video of the tech night this time around.
Thanks for the informative evening.
The E85 sensor lesson and how it reads was a eye opener, especially when they turned E85 to E100 by just adding water to the fuel......and the amount of tanks of E85 to run to clean out the 98 and get back to a higher ethanol content.
And the oring lube that turned to jelly and blocked the injectors leading to engine failure.
Certainly made me rethink the route im taking to fuel setup.
Edited by GTRPSI
Oring lube? What sort of dropkick uses petroleum jelly to fit injectors? A tiny bit of silicone spray is enough and won't ruin anything.
Sounds like it was an ethanol bashing night. Wish I had been there now to dispel the rumours.
lol. not many benefits were mentioned that aren't commonly known, but it was good to know whats involved for piece of mind.
to summarise, you could say the evening focused on:
- things to do or at least keep in mind when converting
- things to keep in mind when running (and buying E85)
- things to do to maintain your car when running E85
Just mentioning what they had seen, customers fitting orings like that without issues in the past because 98 disolved it but E85 reacted differently leading to engine failure.
I was surprised i didnt see your face there scotty, spewing your wernt there for some myth busting. :)
And what about the petrol you buy, do you worry about that?
yeah.
thats why i use 98 from one chain of petrol stations.
im glad E85 is regulated (from Nov 2012) but when United are only supposed to tell you the ethanol content, i was surprised that United wont tell you the RON rating. and when the ethanol content is down to 70% during winter months, I wonder what the RON would be then? for safety you would want a flex fuel meter guiding the ECU to make sure the mixtures are consistent with the fuel (at least i would anyway)
im not bagging the fuel, just playing devils advocate because its not for everyones budget or application.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
