Im getting the switch and some other stuff wired up next week, so ill post a video then. But ive seen them on r32's and VL's. Depending on where on the exhaust they are placed, after how many resonators etc it pretty much sounds like a straight piped race car. Very loud haha
Mostly likely welded.
'Coz it's f**ked.
You have the car right there. Get someone to tap on the underside while you sit in the back with the seat out. You'll find it faster than we will.
Yeah, I'm pretty sure that's how it's going to end up. Mechanic suggested I cut a hole in the chassis/body to access the inside. I can cut the hole for access but will have to get someone else to help if any welding is needed afterwards. Things I'd like to know are:
Assuming there's a captive nut inside, how's it fixed? And how can it be tightening but not fully loosening?
If I cut a hole to access/replace a captive nut, is there a good place to cut for this one? Does it have to be at the side, or is there somewhere I can cut from above inside the car?
