CA18 track car, not fast but potentially fast enough to move fluids around too much. I'm assuming it's fuel surge. Walbro 400lp/h pump.
Car will cough, splutter and miss coming out of right hand corners when the tank is below 1/3rd -so fuel moves to the left.
It's now happening with the tank half full/a little under half.
Still likely to be fuel surge or more likely a wiring issue?
The pump is hose clamped to the hanger as low as I could get it without it touching, I also remove the lower mounting surface from the arm so it was not obstructing the picking.
Surge tank time or something else?
And if surge tank, what's the easiest/cheapest way to achieve this?
https://www.sau.com.au/forums/topic/445031-fuel-surge-issues/
  • Replies 49
High G force turns on slicks will pretty much ruin any chances of keeping the fuel around the pump pickup. Looks like you need a decent surge tank setup. I guess now you need to decide on a budget, because braided teflon and fittings aren't cheap... Will you be looking at an external pump, or trying to fit the walbro into the surge tank?
Only using 235 RS-Rs
I thought with half a tank in it, there should be enough fuel but maybe not.
Budget would be as low as is safe. It doesn't need high end stuff as it's only tracked from time to time and it doesn't use a heap of fuel so flow is not a big problem.
No idea about pumps, whatever is cheapest and easiest. I know I need a second pump but I was under the impression the second pump could be basically anything?
It depends where the surge tank is mounted, if it's inside the car I would want motorsport fittings, not push on rubber lines. Underneath, there are still rocks and crap flicking up...
Or just run with a full tank like I do.
Fair enough, the standard tank has push on rubber hose into hard lines, can't be that bad.
That said, can't hurt to look at prices.
I'll do some searching for some diagrams to show me how all this stuff is supposed to work/be mounted.
Nothing wrong with just efi hose and push on fittings. Ive used it on my surge setup for 3 years no issues and ive actually not been able to take off the lines off the barbs its that tight so no safety issues for it coming off. Cheapest way just get a surge tank and your basic speedflow push on fittings and some efi house and whatever pump you want and problem will be solved for a few 100 dollars.
Well the better pump should feed the engine as it has to build pressure so just get a cheap pump to use in tank,
You can get heaps of info and diagrams on surge tanks by Googling but you could easily spend $1000 although it could be done for less.
I would tend to go with Scotty's advice - just buy a couple of 20L containers and keep your tank full.
Yeah I've got 2x 20L but with the upper half of the tank being another 20L or so it means there's only really 60L of fuel, or just over 1 full tank worth.
During a full track day, up to 150ks plus I can easily go through a full tank and almost both 20L containers.
I could just buy a 3rd 20L container but it's a pain in the ass carting them around.
Not to mention carrying an extra 20-30kg i don't need.
Edited by ActionDan
how is that a good solution? It doesnt solve hes problem cause now you have half capacity of your tank, you have to muck around with bringing more fuel, potentially still having the problem occur if you let it drop again and if your racing around you want to get all the free weight off you can. He can solve thos problem for under 500 and be able to run it down til the light comes on if you wanted to.
If it's trailered to the track, I don't see an issue with the surge. If he drives it... Perhaps not a great idea. I would run the surge as the best option, but hide it well if used on road.
Yeah that was kind of the reason I had for suggesting surge is best option since he said its a track car so I assumed street stealth wasnt an issue but if it was a street car with occasional track then yeah you would sacrafice a little bit and live with having to fill it up.
I assumed I i'd use it to feed the engine but your comment implies it can't be externally mounted?
Just leave it in tank and atleast you know you have a overkill lift pump that you dont have to worry about failing. Pumps are pretty cheap these days so take your pic to whatever you want to use as your surge feed pump. I personally use a 044 but yes they are old and there are better pumps out there but I got a few for cheap and they do the job for me.
So correct me if I'm wrong.
Green - Feed from surge tank through additional fuel pump (to be purchased) that feeds the engine.
Red - Return from surge tank to fuel tank.
Blue - Can be either feed from fuel tank to surge tank or returning from engine
Yellow - Can be either feed from fuel tank to surge tank or returning from engine
Also, standard fuel hose is 5/16th?
Black circle is a hole I'll likely have to cut into the spare wheel well.
Do I need to section off the boot from the cabin now?
Edited by ActionDan
Yeah thats correct, I personally run the return from surge to fuel tank on top but yeah either works whatever you prefer. Youll have to other seal off rear boot from in cabin or make a enclosure for the tank.
Question regarding the feed from the surge to the pump.
Given the feed out of the pump and into the fuel system will be 5/16 EFI fuel hose like what's already there, can the feed into the pump be the same or must it be bigger?
I ask only because that fitting is 10AN compared to the 6AN used everywhere else.
My plane was simply to buy AN to 5/16th barb fittings like these. Though I'm having trouble finding a 10AN to 5/16 barb to so I might have to go 10AN to 8AN then to 5/16.
http://www.ebay.com.au/itm/Speedflow-5-16-8mm-Barb-to-6AN-AN6-AN-6-Female-Hose-Fitting-Adapter-Push-On-/271437188344?pt=AU_Car_Parts_Accessories&hash=item3f32eaccf8&_uhb=1
And then just use something like this hose for everything and these clamps.
http://www.ebay.com.au/itm/370906965297?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com.au/itm/160749548016?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
