Cheers, seems like I'll need some larger diameter fuel hose there then it can step down to 5/16th on the outlet end as per the standard fuel system.
Just thinking any reason I can't fit the pump to the tank directly with suitable connectors and have no hose in between? Mounting heights permitting so it's all level/no load on the fittings.
Edited by ActionDan
  • Replies 49
Question regarding the feed from the surge to the pump.
Given the feed out of the pump and into the fuel system will be 5/16 EFI fuel hose like what's already there, can the feed into the pump be the same or must it be bigger?
I ask only because that fitting is 10AN compared to the 6AN used everywhere else.
My plane was simply to buy AN to 5/16th barb fittings like these. Though I'm having trouble finding a 10AN to 5/16 barb to so I might have to go 10AN to 8AN then to 5/16.
http://www.ebay.com.au/itm/Speedflow-5-16-8mm-Barb-to-6AN-AN6-AN-6-Female-Hose-Fitting-Adapter-Push-On-/271437188344?pt=AU_Car_Parts_Accessories&hash=item3f32eaccf8&_uhb=1
And then just use something like this hose for everything and these clamps.
http://www.ebay.com.au/itm/370906965297?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com.au/itm/160749548016?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Im using 8an fitting from surge to my 044 then the an8 5/16 barb fitting from pump to engine. Dont know about other pumps but I know 044 no issues with AN8 feed.
Can someone help me find the bloody part numbers.
Rather than use standard barbs and clamps I thought pushlock fittings would be better, but trying to find 6an to 5/16 pushlock is proving difficult, I'm waiting to hear back from Speedflow but if anyone knows let me know.
Also any idea if I can just use standard EFI fuel hose with pushlock or if it must be the specific aeroflow/speed flow pushlock hose?
What do you mean 6an to 5/16? As in you want a 5/16 push lock end instead of barb? the pushlock ends are made specifically for those hoses as they are there own diameters made specifically for those fittings so you wont find a push lock fitting made for convential hose sizes, I wouldnt be using normal hoses on push locks. What is your reason of wanting the push locks over the normal barbs?
I simply assumed it would be a better/tighter fit than hose clamps (which I'm not super keen on - though they are used in the standard fuel system).
If there's no gain from them I'll just use standard hose and 5/16th barbs.
There is absolutely nothing wrong with the normal barbs and clamps like I said mine have been on for years and I actually could not remove the barb from the hose i had to cut the hose its that tight, imo even when I use pushons I always still put a clamp on as I still dont like to rely on a push fitting.
Potentially you could use a push on -6 fitting on 3/8 size hose as they are pretty the same dia but yeah I wouldnt recomend it.
heres a pic of my setup anyway super simple and reliable.
Edited by boostn0199
They look nicer again and a 10 pack on eBay is only a few bucks more. Might get those,
I can see they come in various sizes. Any idea what the OD is of 5/16 hose? I'm assuming the 13-15mm clamps are the go?
Outer diameter is 14.7mm so prob go with 14-16 or 15-17 i cant remember which ones I got. The norma sell really good quality clamps if you want good intercooler clamps you can also have a look at these I use them aswell and have never had one pop off.
http://www.norma.net.au/products/hose-clamps/norma/norma-constant-tension-hose-clamps
Try bumping the boost a bit, the fuel will leak past that Norma clamp eventually given enough pressure. I would be running some new 400 series push on hose at a minimum. I guess I worry about ethanol compatibility and leaks/smells inside the car more than most...
You don't like these Scott? http://www.norma.net.au/products/hose-clamps/norma/aba-small-bore-hose-clips
Given I was just going to use the Tridon ones and that's all that's on the standard fuel system (using barbs) I'm not too worried about it not sealing.
It's going to have to use a standard barb fitting at 2 points anyway, as that's what comes out /goes into of the fuel tank.
Plus where I join the surge to standard fuel lines into/out of engine, that's just standard efi fuel hose also.
Yes, but that is in the engine bay, not inside the car. Still, under the heat of the track and hot fuel, the efi hose will soften and the clamp isn't spring loaded to take up the slack. I guess you don't worry about things like that until it happens to you.
Im not sure about your car, but mine get's pretty hot in the engine bay, yet to see a clamp come loose, not bad for original clamps on a 25yr old car :D
I understand what you're saying, I just don't feel that it's as much of a factor for me on a car that only does a few thousand k's a year at most and gets very regular eyes on it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
