Description - RB25DE (R32) Intake manifold and runners
I have modified the plenum to suit turbo set up etc
Both the runners and the plenum have been painted with VHT Aluminium (Colour) and have a VHT clear coat also.
These Units have the same ports as the rb20 manifold but have slightly larger ports so will flow a bit more. These will fit the rb20 eccs engine and rb25de (R32) engine.
I can post at buys expense. I Will include water pipe
Reason for selling - Ended up getting a RIPZ front facing plenum made up instead.
Location - Townsville NQ.
Price - $150.00
Description - RB25DET Crank with Wide oil pump drive collar fitted
I can post at buyers expense
Reason for selling - I decided on an RB30 setup instead of RB25
Price - $250.00
Description - RB20/25 Split Dump pipe
Reason for selling - Old spare one I never needed
Price - $30.00
PM or email me - [email protected] for pictures and more details.
Regards Danny.
https://www.sau.com.au/forums/topic/445062-rb25-engine-parts/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
