Hi guys have a few things lying around I need gone
Location hills area sydney
Prefer cash only pick up
Due to my computer being all screwed up I can send pics via SMS only at this stage
0419575458
All parts where off my r34 gtt and are negotiable
S tune suspension genuine nismo product damper only adjustable
$500
Standard injectors all 6
$50
Standard coils all 6
$50
Standard side mount intercooler
$150
Standard air box with snorkel
$100
Standard gtt 17" wheels w/tyres
$300
Standards exhaust manifold
$80
Standards top half of intake tb included
$100
3" jjr dump pipe bell mouth
$100
Split screamer dump pipe
$50
Passenger side genuine xenon headlight
$300
More to come once engine build done
Cheers
Jason
  • Like 1
https://www.sau.com.au/forums/topic/445089-gtt-garage-clean-out/
Update:
Found more parts
Triple cluster $40
Stock afm $50
Stock fuel pump $20
Stock disc brakes all 4 $50
Stock side lamp indicators $30
Stock front lamp indicators $30
Stock steering wheels with air bag $200
Cheers
Jason
I'll take the coils assuming they are in good condition (were running fine before removal) and that you are happy to post to Melbourne.
At this stage due to work commitments very long hours I am unable to post at this stage
Sorry
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
