The car has been purchased as a one owner car at Japanese dealership -
2003 Nissan Skyline 350GT 6 Speed Premium
3,500cc engine
6 speed manual
Blue
62,000km
ABS brakes
Factory option 6 airbags
Active headrests
Xenon headlights
Traction control
Stability control
Dual-zone climate control
TV/Navigation
BOSE sound system
CD stacker
Steering wheel audio controls
Leather interior
Power seats
Power mirrors
18 inch wheels(with near-New Bridgestone Potenzas)
Brembo brakes
Keyless entry
Factory option security system
Rear Parking sensors
Flawless exterior
Interior condition has slight wear to the leather on the driver's bolster in the usual spot
Underbody has no fluids leaks or rust
Price $19700
located in East Malvern, 3145
[email protected]
0423854047
  • 1 month later...
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
