Its running a pfc, and while it was tuned atleast three years back, it hasnt had any probs.
Im thinking ill have a play with some wiring and see if it changes idle at all... Just wish i had more time to play cars...
Yep, front of the head, sticks out about 50-70mm and has a red/black plug on it
Pull that out and see if it either fixes the problem, or makes the problem constant. If so then not so bad news, might just need a new VCT Solenoid/Switch (this thing your unplugging) or a minor re-tune just to touch up the VCT issue. Perhaps a mix of both
Start the car. Take a screw driver and put the metal tip against the injector. Put your ear to the end of the handle. You can hear the injector clicking, it's working. Go thru all 6 and learn what to listen for. This is the first step of diagnosing a bad injector. Step two is ohm resistance. With the motor off, unplug the wire clip to suspected faulty injector. Use a multi-meter to read ohms. You're looking for anything that is not in the 14 ohm area plus or minus 1.5 ohms. You'll use both prongs of the multi-reader and touch each of the injector electrical prongs. Polarity won't matter. This will tell you if the electrical coil is bad inside. Unfortunately they cannot be rebuilt and the whole injector will needed to be replaced. If replacing a single injector, it's wise to remove the rest and having them professionally cleaned and flow matched to the new one.
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. post-116132-14045372547201_thumb.jpg
These are Nismo 550cc side feed at high impedance.
These are aftermarket top feed that can be high or low impedance depending on your personal engine build goals. Easy to spot. The stock side feeds are purple in color if I remember right.
Here is a website that can help you more with specs:
http://webbersrbguide.com/index.php?option=com_content&view=article&id=64:skline-rb-standard-injectors&catid=45:wiring-electrical-a-ecu&Itemid=23
  • Like 1
Yep ive done the screw driver listen and also the swap, injectors are fine it seems so its electrical or vct, ill check it out further and find an answer...
Thanks for all your input it is much appreciated, just wish i could dedicate more time to it...
  On 05/07/2014 at 5:25 AM, FBRacing said:
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. attachicon.gifImageUploadedBySAU Community1404537253.775014.jpg
Thanks for the link mate, very helpful :)
Ok im still trying to sus this out, ive tried unplugging injectors one at a time and all make a slight difference to how it runs, ive changed spark plugs, removed coil plugs ones at a time each makes a difference to how it runs...
I havnt had a mechanic do anything on my car other than tune or fab work for years, normally do everything myself, but i may have to bite the bullet cause this has stumped me... Silly cause i feel i caused it.
Could an electrical issue cause by moving old heat and weather affected wiring harness...
  On 17/07/2014 at 8:56 AM, 75coupe said:
It could be, but the filter isnt that old, and it was running fine before painting some parts...
But now that youve said that perhaps i should change it just to be sure...
Put a mesh 40 micron on there, all the blocked ones I have seen lately have been Ryco style paper ones. Never had an issue with stainless mesh filters.
It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug.
I closed the female connection a little, plugged it back in and the problem hasn't resurfaced.
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
