scotty nm35 Posted July 20, 2014 Share Posted July 20, 2014 It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug. I closed the female connection a little, plugged it back in and the problem hasn't resurfaced. I agree, I have had this head f*ck a few times. It can be a pita to find, depending what pin it is. I swore the issue was dry joints in the ecu last time, but it was just the pin in the ecu plug had opened slightly. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7344547 Share on other sites More sharing options...
FBRacing Posted July 20, 2014 Share Posted July 20, 2014 I agree, I have had this head f*ck a few times. It can be a pita to find, depending what pin it is. I swore the issue was dry joints in the ecu last time, but it was just the pin in the ecu plug had opened slightly. I do know a guy that had the same issue also. He had to re-pin his ECU. Problem solved once done. Just figured it was just isolated deal for him since he swap a RB into a S chassis. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7344588 Share on other sites More sharing options...
75coupe Posted July 20, 2014 Author Share Posted July 20, 2014 Ok thanks for the suggestion ill check it out... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7344847 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 Ok update Ive confirmed injectors are all working I have continuity tested coil pack harness and injector harness. Does seem to idle slightly better with cas unplugged but still rough New spark plugs Compression test came up with all cylinders fairly the same Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355262 Share on other sites More sharing options...
89CAL Posted July 31, 2014 Share Posted July 31, 2014 It shouldnt idle at all with CAS unplugged :S How would it know when to fire injectors + Spark? Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355263 Share on other sites More sharing options...
Missileman Posted July 31, 2014 Share Posted July 31, 2014 I would think he meant to type AFM Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355274 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 Oh sorry the vct unplugged Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355281 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 The most annoying part is, it was running fine before painting some parts... What have i done...? Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355286 Share on other sites More sharing options...
89CAL Posted July 31, 2014 Share Posted July 31, 2014 Did you paint an Earth or anything like that? Which parts did you paint/remove and paint? Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355290 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 Injector caps were removed and paint, vct extending out past rb26 belt cover was painted whilst on car, no belts removed everything masked. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355326 Share on other sites More sharing options...
r31 25t Posted July 31, 2014 Share Posted July 31, 2014 Did you re-set timing after re-installing the cas? Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355381 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 Well it didnt move as i made key marks to re-align it. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355385 Share on other sites More sharing options...
r31 25t Posted July 31, 2014 Share Posted July 31, 2014 It might pay to check if the halfround is still in the exhaust cam. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355390 Share on other sites More sharing options...
75coupe Posted July 31, 2014 Author Share Posted July 31, 2014 Yep did that Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7355391 Share on other sites More sharing options...
r31 25t Posted August 1, 2014 Share Posted August 1, 2014 Check the pins in the injector connectors too, the pic on the first page looks like they might trying to come out the back. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7356215 Share on other sites More sharing options...
75coupe Posted August 27, 2014 Author Share Posted August 27, 2014 Ok i think ive narrowed it down after checking everything twice, i think the timing is out. Ive the cam belt cover off a few times over the years and never a prob, could it be the cas is just decided to die. Or the wiring loom has finally broken? I put a timing light on it and nothing lines up, used the white wire going to no1 spark plug. Pfc is now saying 24deg and then bounces to 16 and everything in between when warm. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7375177 Share on other sites More sharing options...
89CAL Posted August 27, 2014 Share Posted August 27, 2014 use a lead between the plug and coilpack. The wire method rarely works 1 Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7375484 Share on other sites More sharing options...
75coupe Posted September 6, 2014 Author Share Posted September 6, 2014 DVS found the issue to definitely timing, belt skipped three teeth, damn lucky to not have caused major damage, so it shoild all be sorted for track day currently getting timed and some stuff replaced... First time to a mech in 6yrs, and im glad i did Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7383577 Share on other sites More sharing options...
Ben C34 Posted September 6, 2014 Share Posted September 6, 2014 Wow. Very lucky! Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/3/#findComment-7383598 Share on other sites More sharing options...
