Hi
I'm getting a bigger turbo for my gtt and I'm wondering if I need to get an aftermarket ecu and a tune or an apexi afc to controll the air:fuel ratio. Does anyone know what's better for a car ? Also nistune or power fc for an auto? I know there's a lot of threads but they all have different answers.
Any help would be greatly appreciated
If the car is an auto I dont think the power fc will work If I can remember correctly. I think your best bet would be nistune and there running r35 afm now with good results. The afc gives control of adjusting the afr's but your hands are tied when it comes to tuning the ignition curve. The last and best option but way more costly is somthing like a motec or haltech ecu. Where the options are endless.
Yeah, what MJTru said.
Essentially, for a stock turbo the AFC can yield acceptable results but if you are going for a bigger turbo (which means to really do the job right you also are going to change the AFM and injectors- and fuel pump if that isn't already done) then a nistune will probably be your best option for an auto. Perhaps even consider a Toshi tune (search for this).
Edited by jjman
You can run an AFC or nistune with the auto. The others won't pull timing on gear changes and will destroy your transmission pretty quickly from what I've heard.
AFC's are no good, even with a stock turbo there isn't much point of running a piggyback like that. I'm sure there was a time when it was a good idea but not anymore I guess.
nistune it is.
  • Like 1
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
