The New Official S A U - N S W Spotted Thread
GoldZilla
  • 3 weeks later...
Saw a black R32 (gave a little wave) and blue R34 in Austi Beach around 1ish today!
Also saw a silver R32 leaving the Motors & Meatballs event at Enzo Cucina in Glen Apline... nice exit!! better than most of the exotics
Spotted a beautiful silver R34 GTt heading north (away from the freeway and towards Panthers, etc.) on Mulgoa Road in Penrith on Friday night around 7pm, it was lowered to perfection (in my opinion) and sat on a nice set of dark grey or black wheels - can't remember what type/style they were, unfortunately.
Spotted after Powerplay in Sydney a blue r34 GTR with GTR70Y plates anyone know who it is and if so message me I was the one having a play with him in a blue r35 I'd like to know how much power he has etc
Ps it sounded mental in boost :)
Had some fun with a white R34 GTR, southbound on Hume Highway through Liverpool, about 6:30 this evening. Saw an R34 sedan on Glenfield Road just after. Spotted an R33 on Glenfield Road a couple of hours before the 34s. Lots of Skylines out today in the Liverpool area.
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
