On 16/10/2016 at 11:28 PM, barnoon said:
Spotted a black or grey 33 on Hawkesbury road Springwood a couple of days ago. Gave me a thumbs up, waved back. I was in the white 32
Hmm, do you remember the plates and was it at night?
I spotted a Grey 32 up there the other night too - Was parked next to an evo
Spotted a white R33 with a gtr style wing pulling out of the Shell on Briens Rd Northmead heading towards Cumberland Rd this morning somewhere around 7:30.
Spotted a R31 on the way home on the same stretch of road headed in the opposite direction. Plate was 31DET if I remember correctly.
Spotted a matt black R33 with a drift lip style rear wing parked off wonderland drive eastern creek today.
And a red z32 300zx driving down Wonderland drive toward Walgrove road at about 2:15
Edited by Gibbon138
forgot the Z
I saw the matt 33 also - Series 1 with MSpec front bar right?
  • 4 weeks later...
3 different black R34 GTT's in Penrith today.
1st, Castlereagh/Mulgoa Roads at around 7:45 am. Stock looking body, FMIC, exhaust, staggered wheels, lowered.
2nd, parked in a car park I see it in a bit. Blody kit, exhaust around 10am.
3rd, 2:50 PM with vented bonnet and high GTT wing going to Autobarn
Spotted a GMG R33 GTSt (rego 94-GTST) yesterday in the car park in Winston Hills shops and was following it along Caroline Chisholm Drive, then Powers Rd, then Station Rd until I turned off into my street to head home.
I was in my white Golf wagon
  • 3 weeks later...
  • 1 month later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
