High Energy Rwd Rb26 Sump
By soviet_merlin · Posted
I always find it both fascinating and educating seeing you go through all this. It's a bit like "BMWs are great. Except with one massive caveat: as long as you fix this two page long list of things where components are broken by design" Every now and then I consider getting a BMW. And then I read your posts and think that maybe the RB life is not so bad after all -
For the record, I hate the colour. Even if I'll never see it again, I know its in there.
This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails. As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
