Gday everyone,
I have installed a fake Greddy front facing plenum on my RB25 in my R32, so now looking at getting the piping from the throttle body to the intercooler sorted.
What have you all done when faced with this? Ive had some quotes ranging from 500 to 1500, have thought about doing it myself, plus im keeping an eye out on the classified sections.
On top of this, what are thoughts on 2.5 or 3 inch piping on the cold side? From a bit of reading 3 inch could be a bit laggy but others have said it will be fine.
Trying to keep on a budget and be a tight ass!!
Cheers
Edited by Strick.
The chance of picking up custom piping that fits properly is slim, and most go through the battery tray. If you want a neat legal job done you are best to find a local fabricator that can run a pipe down beside the radiator.
Are you doing both sides? Those quotes seem on the high side imo, $600-$700 should cover both hot and cold pipes in stainless or alloy, including joiners and clamps.
Sorry mate, should of added its for a track car and i have already moved the battery to the boot.
Those quotes were just for the cold side!!!
If anyone knows of someone that can do it for a good price please let me know
I have 3" in and out on the cooler. Had 2.5" piping all round with stock throttle body (expanded to 3" obviously for each in/out on the intercooler). Still have 2.5" piping on the hot side, 3" on inlet side cooler to throttle body. Talk to the fabricators and the tuners, they will be the best ones to give advice and give technical answers as to why but the setup I have works well.
Thanks guys,
Have spoke to DVS JEZ and he'll be getting my business. Going 3 inch.
Going to purchase another cooler first, as it seems its too much work and not worth it to adapt the return flow cooler.
Cheers!
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
